Thread: Side airbag removal help
    Stoke on Trent
    Default Side airbag removal help
    Morning folks!
    Does anybody know how to remove the drivers seat airbag unit?
    One of mine has gone off, and I need to get the old one out,
    Cheers,
    Dan
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Remove back panel this simply pulls down and out then lean on rear springs on seat to reveal side airbag iirc there's 3 or 4 small 7mm nuts holding it in once it's out there's a locking tab on top just lift the tab up to release
    Make sure you disconnect battery before doing it tho
    Since airbag has been deployed you might need to get airbag ECU reset or you may have to buy a new one to get airbag light off.
    Irmscher Insignia CDTI 130
    Stoke on Trent
    Brilliant!
    Thanks for that! I Shall have a stab at that tonight!
    Stoke on Trent
    Just a quick question...
    The back panel we are referring to is the panel with the pocket in?
    Also, I know the upper part of the seat bends forward because of the active headrest thing. Is it a case of simply putting my fingers between the back panel and the upper part of the seat and giving a sharp tug downwards?
    Stoke on Trent
    Hi again folks,
    Having real trouble getting the back of the seat off!!
    Is there a knack to it??
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Should just pull out iirc pull it from bottom
    Stoke on Trent
    ive pulled and pulled to the point at which my fingers are going through the fabric...
    I'll give it another go..
    Cheers for you help
  1. Airbag removal, please help.
    By tammyman09 in forum Bodywork & Interior
    Last Post: 26th February 2011, 14:21
  2. Airbag badge removal?
    By jamesr in forum Styling
    Last Post: 15th June 2008, 10:49
  3. airbag cpu removal
    By monkyspunky in forum Bodywork & Interior
    Last Post: 11th May 2008, 10:45
  4. Help, airbag removal etc...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2007, 00:02
  5. airbag removal
    By TonyR999 in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2007, 16:50
vectra c seat airbag removal site:www.vectra-c.com
