Results 1 to 10 of 21
Thread: My instrument panel cluster is not working
    Apr 2011
    ELGIN
    Default My instrument panel cluster is not working
    I have got VAUXHALL VECTRA EXCLUSIV CDTI 120 5 DOOR HATCHBACK 1910cc.
    Its trip meter was not working. I took it to local Vauxhall garage.
    They told me that we need to replace its instrument cluster panel. Which cost me more than £400?
    Any one knows any cheaper solution.
    Everything else is ok only trip meter reset button does not work.
    If I get a used instrument panel from somewhere, can any one change it.
    Any idea where can I get used instrument cluster panel and how can I change it.
    I live in north of the scotland
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    so its one of these by the sounds of it probably a TID..
    (great pic, not my work, its borrowed from another forum)
    You can buy most of these secondhand on there own but i believe you are best buying it with its accompanying stereo headset as they are paired using Tech2, well I know that is the case with CID and GID screens, i guess BID and TID will be the same..
    when you refer to the cluster though that general means the clocks containing the speedo and rev counter etc.. well it does to me...
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    11 Post(s)
    Sounds to me that the OP is talking about the speedo binacle, not the stereo display.
    The clue being the trip meter & trip reset button not working. There isn't a trip reset button on the stereo display - that's done remotely from either the wiper stalk or button on the steering wheel.
    Regular Member Jezzy's Avatar
    S.E
    There are several for sale here:
    http://www.carpartsconnexion.com/vau...ar&cat=24&p=4&
    Do you know the part number for the one you need? If so, match it to one on the above link, if not then fill in the enquiry form on the link above and quote your reg number and ask them to advie if their part fits your car.
    Jun 2009
    South Coast
    ah right the 'trip meter' threw me, was thinking of the BC trip computer..... yeah its the cluster then.. is that quote for the part only then?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    If your on about the clocks they come out it no more than 5 mins. Not sure if there paired to the car though?
    Full Member
    South West
    i had a VXR cluster in mine for a while and it just worked. The only problem with buying second hand is the milage on the cluster will be different to that of the ECU.
    This can be changed, but a reputable person doing a milage change will need to be provided with proof that you are doing it for legitimate reasons and not fraudulant.
    S.E
    They're not paired - when Kman does his LED dash conversion, he swaps out your instrument pack for a spare one he has at home, and then swaps them back the next day.
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    clock are paired to the cars system and need to be done properly to not throw up any error codes and to make sure all the options for your car are set....
    As above though they will 'just go in' and work without doing them properly.
    Apr 2011
    ELGIN
    Hi guys
    Thanks for all advices
    My problem is with cluster panel (on which Speedo meter fuel gage temperature gage etc fitted) not with stereo panel
    please picture
    I have contacted couple of person who do milage correction one of them says to me we cannot change this panel as all of the vehicle security information stored on it. Other one says we can change it no problem.
    I am confused now. Can I change it or not. If it can be then where can I find second hand?
  1. instrument cluster
    By waky in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2011, 00:31
  2. instrument cluster
    By veccyv6 in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2011, 19:03
  3. Instrument Panel Dials Not Working
    By mick mcm in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2010, 15:13
  4. Instrument cluster
    By Daywalker in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2008, 18:43
vauxhall vectra speedo not working
vectra c speedometer not working
my vectra c has a problem with the cluster
vauxhall zafira instrument cluster changed now it will not start
vectra c instrument panel
insignia trip meter doesnt work
vectra c instrument panel not working
Vauxhall instrument panel replaced now not starting
vectra instrument panel stops working when driving
vauxhall vectra c speedometer not working
vauxhall insignia rev counter and speedo not working
vectra c speedo not working
