Results 1 to 10 of 16
Thread: Irmscher 3 leg spoiler fixings
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Question Irmscher 3 leg spoiler fixings
    Is there a bolt in the middle or is it just bonded?
    I've got a rattle coming from the boot lid of my car and it appears the centre leg of the spoiler isn't tight onto the body work
    Woodbridge
    May sound like a real silly question mate, but is it the same with the parcel shelf out?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    TBH i've not tried that yet bud but the spoiler is definatly rattling as you hear it when you shut the boot lid.
    Not so bothered about the rattle, just don't want to see 300 quids worth of spoiler disappearing off the back of my car
    Regular Member Marc Hutton's Avatar
    Edinburgh/Catterick
    Have you had look when the boot is open M8 cause if it is a bolt will be located inside m8 that where mine are Bud.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Yeah there are 4 bolts (2 at either side) on the outer legs. I wouldn't see the middle one without removing the interior trim
    Woodbridge
    I have the same spoiler mate and have a bit of a rattle, but I have put it down to the parcel shelf, which I need to fix.
    SCOTLAND
    John mine is just bolted on the outer legs and bonded on the centre but mines loose as well. Not bothered to re stick yet as i am going to take off to polish up the bootlid first.
    Full Member paul.sessions's Avatar
    leighton buzzard
    does the two leg irmscher one fit into the same holes then ?????
    Tyneside
    Common for the centre part to come loose on these spoilers John, helps that you can then remove it. Mine is currently hanging on by one bolt either side after some retarded idiots decided to push the car via the spoiler
    West
    i had a problem with my preface spoiler (irmy 3 leg) it rattled a bit & wouldn't tighten up right... my cure was to remove, then cover the feet with some cut to shape number plate adhesive pads then refit... this worked for me.
  1. Irmscher DTM spoiler
    By bigmac in forum Styling
    Last Post: 17th April 2010, 14:38
  2. irmscher spoiler with sri lip spoiler
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2010, 18:39
  3. Irmscher spoiler pic, hot or not ?
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2007, 01:38
