Results 1 to 3 of 3
Thread: radiator how to?
    Aug 2010
    derbyshire
    Default radiator how to?
    i have got to change my mates radiator on his 1.9 cdti (120) vectra and wondered if anyone else here has done this and could offer some tips as it looks a pig of a job to get at
    thanks
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi steve
    it's a fair old job the radiator is taken out downwards,remove overflow hose,wiring harness,charge air pipe,vacuum line,front panel,headlights,lower rad brackets to loosen,top coolant hose,bottom coolant hose,unbolt dryer and move to side(2 bolts)intercooler,bottom rad brackets.remove rad downwards you will need a second pair of hands it's a little heavy and awkward. as i said a fair old job good luck have fun he he
    i may have missed a few bits and pieces but you will find them if so
    Aug 2010
    derbyshire
    cheers for that mate, i will look forward to this........................NOT!!!!!!!
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. Air con radiator
    By sebadee in forum Troubleshooting
    Last Post: 27th September 2011, 20:33
  3. Radiator on 3.2 GSI
    By JJGSI32 in forum Troubleshooting
    Last Post: 4th February 2011, 22:18
  4. Air con radiator
    By VECTRA HEAD in forum Engine & Drivetrain
    Last Post: 24th March 2010, 13:38
  5. Radiator
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 11th February 2009, 22:04
