Results 1 to 10 of 30
Thread: does every vec c have tc??
    Apr 2011
    glasgow
    Default does every vec c have tc??
    just been reading thru the posts and saw that you could replace the blank button at the bottom of the alarm if you have the blue switch?? but not sure if mine has tc? or do all vecs come with tc as standard and you cant swith them off on the early models if the switch isnt there? cheers!
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    1.8's don't and apparently neither do the later facelifts. To check, open the bonnet and behind the battery compartment there will be a little silver box with 4 hoses coming out of the top of it. This is the ABS module, on the side of it it will say either nothing or TC or ESP. If it says one of the latter two then you either have Traction Control or Electronic Stability Control.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Bristol
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Great bit of info, im off out to look now
    Apr 2011
    glasgow
    sure is gd info! thanks! ill check to see if it has this! hopefully not as i think it would zapp some of the power? mines is a 53 2.0 turbo! the car has been remapped before i bought it! was thinking with it been remapped it would have disabled the tc? either that if i fit the switch and it doesnt work is there any other way to disable it? cheers!!
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by strathy View Post
    For one you will have TC and a switch stands a good chance of working on yours.
    It can't be disabled via a remap to my knowledge.
    Gazza4
    Apr 2011
    glasgow
    fingers crossed the switch works then! lol
    and if you havent got a switch dont get it from ebay
    they are cheaper at the dealers
    Regular Member Jezzy's Avatar
    S.E
    Gazza4
    That rule didn't work on my car. I got the right answer by looking at the list of equipment fitted to my car in EPC.
    Regular Member m111kan's Avatar
    Liverpool & Norfolk
    Gazza4
    i suppose a 57 plate would be a later facelift??
    alex
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by m111kan View Post
    alex
    Possibly m8.
    Gazza4
