Thread: faulty thermostat/limp mode/spanner light
    Regular Member collyb's Avatar
    Mar 2011
    ireland
    Default faulty thermostat/limp mode/spanner light
    guys would a faulty thermostat cause limp mode/spanner light ??????
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Nope but a duff water temperature sensor would.
    Mar 2011
    ireland
    is that the wee sensor on the side of the thermostat housing ????.... how can i tell if its gone ???
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Should be yeah, which engine do you have? I'm not sure apart from reading the fault code or trying another one in it. If you were somewhat closer you'd be more than welcome to swap it and see if everything worked ok.
    Mar 2011
    ireland
    ive the 1.9cdti sri mate,,,,, my head is fried big time with this car,,,nearly 1000 euro spent on it in the last 2 weeks and still not going right,,..... the engine tempersature guage only rises at idle or moving through town,,but when out on the open road at 6omph,,it drops back to cold,,,,this would point to thermostat ?????? i dont know what to think anymore,,,,,my last hope is that if i do the 3rd injector wiring mod,,,it will sort it
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    your best bet is to read the fault codes,expensive to keep replacing parts as you know by the trouble you have had
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I'd take the thermostat off and test it in boiling water to rule out any faults with that. If it seems ok, try and get a temperature sensor for it and go from there. A bad thermostat wouldn't cause any errors but the sensor would.
  1. 2.2 DTi spanner light and limp mode only at motorway speed
    By cont1204 in forum Engine & Drivetrain
    Last Post: 31st May 2011, 19:30
  2. Spanner Light but no Limp Mode
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 13:07
  3. limp home mode but no spanner light??
    By mick 1986 in forum Engine & Drivetrain
    Last Post: 5th April 2009, 12:22
  4. Replies: 33
    Last Post: 30th December 2008, 19:08
  5. spanner light on 2.2 dti and goes in to limp mode
    By thelad in forum Engine & Drivetrain
    Last Post: 14th March 2008, 21:48
vectra c thermostat light
vectrac.com vectra cdti limp mode when cold www.vectra-c.com
can a temperature sensor cause car spanner light.vectra
signum 1.9 cdti change thermostat car is in limp mode
spanner light on vauxhall vectra thermostat
can thermostat cause limp mode
