Results 1 to 10 of 15
Thread: Front Chrome V : Confused slightly with what's underneath
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Default Front Chrome V : Confused slightly with what's underneath
    Hello all
    I am in the process of sanding down for painting my Chrome V from the front bumber.
    I have had to cover up some large holes on the top of the grille with gafer tape after i removed it but what confusd me was the opel moulding underneath.
    Is this normal ? I suspect this is not the original item as when I took off the front bumper the first time it had my REG written on it in pen on the inside ....
    Its growing on me but the V will go back on once I have finished the sanding and primer preping then off to a paint shop for spraying.
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Thats normal, Im sure that all grilles have the same opel blitz on them, the VXR grille on my old car has the same, as did the factory grille I took off, thats why there's a black backing behind the griffin badge to stop you from seeing the opel blitz
    It's normal mate - all of them including the VXR use the Opel grill then put the VX badge and chrome part over the top of it. Saves on making 2 different grills...
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thanks lads. That makes perfect sense when you think about it doesn't it.
    I feel somewhat dumb now but enlightened
    Regular Member KELLSY84's Avatar
    Feb 2011
    belfast
    did you remove the front bumper to remove the v grille. i need to get mine off for the same reason.
    Regular Member m111kan's Avatar
    Liverpool & Norfolk
    the opel blitz looks better than the v IMO
    alex
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Hi Kellsy84
    Yep had to take the front off, but once off it was pretty easy to remove the V.
    You just have to work out what clips onto what. I then got out all my flat head screw driver bits and wedged them in slowly and carfully into the lugs then started to easy it out again slowly and gently.
    I was suprised how easy it was to get off as I have read some horror stories on here about breaking clips. I just took my time (around 15 mins) easing it out.
    Would a rear shot of my V help you with what clips to attack ?
    EDIT : m111kan i was thinking the same but the V will go back on as im about half way through this project now.
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    These clips are a nightmare, sooo fragile :/
    Yep mate, plastic frame grille is the same, just V-chrome part is different. See, Opel rules
    Feb 2011
    belfast
    no its ok Envy i have had it off before when i changed my grilles to vxr honeycombe but thought you might be able to remove on the car, ill bring it down to my dads garage and use his ramp ( and tools ) at the weekend.
    ps could anyone tell me how to put pics on. thanks in advance lol
    Oct 2010
    Poland
    Quote Originally Posted by KELLSY84 View Post
    "go advanced" button, then "manage attachments" -> browse folders-> upolad.
    You also have option "preview post" which gives you possibility to see if right pics has been uploaded and their position
  1. Replies: 7
    Last Post: 6th February 2013, 19:55
  2. Water stilling underneath the front Passenger seat no
    By akeem in forum Bodywork & Interior
    Last Post: 18th December 2012, 14:35
  3. Confused over front brake disc size Signum 2.0t
    By Envy in forum Suspension, Wheels & Brakes
    Last Post: 10th May 2012, 16:40
  4. whats underneath the front grill V?
    By kalioon in forum Styling
    Last Post: 12th February 2012, 16:47
  5. Out of line front bumper.......slightly
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2008, 18:13
