Thread: help
    Apr 2011
    west yorkshire
    Default help
    Hi all, we have always run vauxhalls and have just been offered a 56 Vectra, registered Jan 2007, its the Vectr CDTI Design 150 estate, 120.000 0n clock. Water pump just collapsed, so been repaired and cambelt done at the same time. Car still will not run, garage apparentley no idea why??????? Is it a case of leave alone, or cheapish repair, buy or not at £2200. Its automatic by the way. Thanks for any input.
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    If the garage can't fix it I would say leave it!!!
    Full Member
    Mar 2011
    n. ireland
    walk away, walk away ps. its also a song
    Regular Member Jezzy's Avatar
    S.E
    That engine has enough troubles ready for you at the best of times. With the high mileage and the existing problems added to the mix, you'd be a sucker for punishment to buy that.
