Thread: Inner Tie Rod Guide
    Feb 2011
    Chatham, Kent
    Default Inner Tie Rod Guide
    Hi all,
    Have a horrid noise and after a free suspension check i was told the inner tie rods were in a shocking state.
    I've tried searching on here but the search doesn't like the words i used so i can't find a guide.
    Anyone got a guide on doing them? I've already bought them, apparantly they are called drumsticks in the trade.
    Are they easy enough to do as i've never done them before?
    Thanks,
    Andy
    first thing is to remove the track rod end from the swivel on the hub
    right then there is a gaitor on the steering rack that covers the drumstick end of the inner tie rod
    undo clamp/cable tie on the OUTER bit of the gaitor and then push the gaitor towards the other side of the car
    you will then see the drumstick bit of the inner tie rod
    there is usuall a spanner shaped nut on the ball end that you have to undo
    If i can recall correctly i believe its a 32mm spanner
    then just unscrew the drumstick with track rod end still on it
    when you have it all off the car undo the locking nut for the track rod end and wind the track rod end of the inner tie rod , while counting how many turns it takes to unwind it
    then remove the locking nut from old inner tie rod and wind it onto new inner tie rod
    then wind the track rod end onto the new inner tie rod the same amount of turns as it took to remove it off the old one , then tighten locking nut
    screw new inner tie rod onto steering rack , tighten , grease and then reattach gaitor
    make sure gaitor clip is tight so no grease can get out
    reattach track rod end to hub swivel
    replace track rod end nut
    recheck everything is tight and viola
    job done
    now go get your 4 wheel allignment done as it will be out
    hope this helps
    ( not bad from memory )
    Feb 2011
    Chatham, Kent
    Quote Originally Posted by marktaylor View Post
    job done
    hope this helps
    Thanks, will give this a go tomorrow
    Andy
    north east
    Will be intersting to see if the clam / cable tie etc has been replaced recently or not ;-)
  1. guide/ photoshop
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2010, 14:35
  2. sky hd tv guide
    By solorider in forum The 'Off Topic' room
    Last Post: 12th May 2010, 12:43
  3. Nurburgring guide
    By smithi in forum General Chat
    Last Post: 16th April 2008, 10:55
  4. a how not to guide
    By vectra 2.0 t in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2005, 13:42
  5. boy racer guide
    By chunkster in forum Comedy & Humour
    Last Post: 7th August 2005, 22:58
vectra c inner tie rod removal site:www.vectra-c.com
