Thread: Vectra 2.2 Direct intermittent misfire?
    Regular Member simp_2.2sri's Avatar
    Cheshire
    Default Vectra 2.2 Direct intermittent misfire?
    Up until very recently, my car has behaved perfectly for months on end which is very unusual!
    Basically I can be in any gear at any speed and the engine will splutter/misfire very briefly, say for a second or two then clears itself.
    It feels like a fuel starvation problem rather than ignition. This has been happening for a few days now and will happen consistently every few miles.
    I am well aware of the high pressure fuel pump and regulator problems surrounding the z22yh engine as I have replaced the regualtor twice already!
    There are no warning lights at all and no codes stored.
    If my hp pump is about to go up the swany, surely I would have codes relating to low fuel pressure (P1191) like I did when the regulator went faulty?
    I think I'll change the fuel filter for a start but any thoughts/advice would be greatly appreciated
    Cheers.
    Cheshire
    Anyone?
    Blantyre
    Edit :
    You won't get any codes on the HP fuel pump, mine went a few weeks ago, some garage pointed to the regulator, but it was actually the pump after Vx tech2
    Cheshire
    Quote Originally Posted by spennny View Post
    Edit :
    Thanks for the reply.
    With my obd code reader showing live readings, I think I remember seeing the fuel pressure of around 5000kpa when it's running normaly.
    In theory, if it's the hp pump thats failing, when it does it's spluttering/misfiring, I should see a drop in fuel pressure?
    I hope it's not the pump, it looks easy enough to change but cost £300.
    Oh and one more question, howcome a failed hp pump doesn't throw up any codes or engine management lights?
    Thanks again
    Blantyre
    Dont know mate, when mine went i was sitting stationary, the EML came on and then the car hit limp mode, no warnings what so ever, the AA couldnt get a reading and i got to a garage, the instantly thought it was the regulator till i told them it had been replaced, so they told me to contact Vx.
    Vx had the car a few hrs and told me the reg was indeed throwing the fault but it was the HP pump at fault,
    Its a 20 min job to do, but as you said its expensive, there about £200 from ebay, and vx parts i think,
    Cheshire
    Thanks for the reply Spenny!
    If anyone else has any suggestions/ideas I'd be very greatful
    Cheers.
    nottingham
    As spenny suggests sounds like the pump - mine went into limp mode with eml light on but has now changed to engine light and splutters and sounds like it's firing on 3 when you give it any revs. AA could not get any codes, took it to vx today for a recall on the fuel pressure regulator which they say has not fixed the prob and therefore it is the pump that has failed - £500 to replace at 35k its a joke.
    Blantyre
    500 quid,
    it's a 20 min job, get a pump from eBay or Vx parts online, make sure it's continental, and u will be fine
  1. 2.2 direct misfire
    By lh_4827 in forum Engine & Drivetrain
    Last Post: 22nd November 2013, 19:55
  2. 2.2 Direct 54 misfire sometimes
    By rodzynx in forum Engine & Drivetrain
    Last Post: 4th March 2012, 12:22
  3. Slight Misfire & (Intermittent) No Power When Engine's Cold (1.9 CDTI 150)
    By DanR in forum Vectra C / Signum Troubleshooting
    Last Post: 11th March 2011, 21:13
  4. Intermittent hesitation / misfire / fuel starve
    By rheumatoid in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2009, 10:35
  5. Vectra 2.2SRI Direct Misfire/Limp Mode
    By craig123 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2009, 22:28
vectra c intermittent misfire
https:www.vectra-c.comforumshowthread.php135656-Vectra-2-2-Direct-intermittent-misfire
vauxhall vectra 2.2 direct misfiring
vauxhall signum 2.2 direct misfire low gear
vauxhall vectra c misfire
zafira 2.2 misfire no lights
vauxhall vectra missing
vectra c intermitent misfire no warning lights on
vectra c 2.2 misfire
2.2 vectra intermittent misfire
