Thread: Fault codes after service.
    Durham
    Default Fault codes after service.
    Hi All,
    I have a Vectra 1.8 petrol on a 54 plate with about 72k on the clock
    I read the fault codes using the pedal method and it showed 1565, but everyting worked fine.
    Last week I serviced it (plugs, air filter, oil, oil filter) and after this it showed codes 1565 and 0100 - Air flow sensor.
    The idle was a little bummpy so i cleaned the throttle body put it back together and now it shows codes 1565, 0100, 0220, 0120 and 1550.
    It still drives ok and if I didnt keep reading the codes i would be non the wiser.
    Any ideas the cause of the codes??
    Thanks,
    Regular Member Jezzy's Avatar
    S.E
    P1565 shows on my list as "Speed Control Command Switch Out of Range High", which I have to confess is french to me.
    P0220 is "Throttle/Pedal Position Sensor/Switch B Circuit Malfunction"
    P0120 is "Throttle Position Sensor/Switch A Circuit Malfunction"
    P1550 is "PSPS Out Of Self Test Range"
    Durham
    Cheers Jezzy,
    Is it just a coincidence that it started spitting out falut codes for the MAF after I changed the air filter and started complaining about the throttle after i cleaned out the TB. What is the last one all about?
    Full Member
    South West
    i had the 0220 and 0120 after removing and cleaning my TB. Used a code reader to clear them down and no problems since.
    Dont be too worried about these two mate
    S.E
    Did you have to undo any electrical connectors to remove the TB? If so, make sure they're properly reseated.
    Full Member
    South West
    There is one connector on the TB which needs to be removed
  1. Fault codes
    By conman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2013, 15:37
  2. help with fault codes
    By vectragsi3.2 in forum Engine & Drivetrain
    Last Post: 28th January 2011, 19:11
  3. Fault Codes
    By MURDO in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2011, 09:32
  4. Fault codes...
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2009, 13:56
  5. 2 fault codes
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 12:49
