Results 1 to 2 of 2
Thread: drive shaft oil seal replacement
    Apr 2011
    leeds
    Default drive shaft oil seal replacement
    i noticed a small patch of oil on the drive this morning so took the vectra to local (to work) fast fit garage.
    got it on the ramps and there is a small leak coming from the OS driveshaft.
    mechanic says it need a new seal, they cant do it as they only fit tyres / brakes etc.
    anyone on here changed one? looked like a steady job (on the ramps) not sure how easy it would be on the axle stands in the garage
    cheers Paul
    Aug 2010
    Leeds
    Yes drive shaft seals should set you back half a day from start to finish.
    Quicker if you have done a few.
  1. gearbox drive shaft seal
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2012, 20:15
  2. Oil leak from o/s drive shaft seal
    By olid2002 in forum Engine & Drivetrain
    Last Post: 21st March 2011, 23:51
  3. Crank Shaft Oil Seal !!!! PLEASE HELP!
    By s0501291 in forum Engine & Drivetrain
    Last Post: 24th April 2009, 19:53
  4. Cam shaft oil seal leak
    By exclusive07 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd January 2009, 22:05
vectra c driveshaft oil seal replacement
