Results 1 to 10 of 19
Thread: ongoing CC problems
    Edinburgh
    Default ongoing CC problems
    Chaps,
    My cruise control is knackered. Keeps cutting out on my and sometimes won't come back on. Did some searching on here and so far I've replaced the stalk and the clutch pedal spring, still no joy. I'm thinking the next step would be the clutch switch since I'm not aware of a problem with the brake switch since the brake lights seem to work fine. Does this seem a reasonable next step?
    Anything I've missed or anyone have any other suggestions?
    Seeing as you'll be under there, it might be worth changing them both on spec mate - clutch switch definitely next step but depending on price get them both done...
    May 2008
    Tyneside
    Think there are two contacts in the brake switch, one for lights and one for CC, so might be worth replacing. Alternatively could try switch with a meter. HTH
    Blantyre
    I have similar issues mate, mine works intermittantly
    Was the spring / stalk hard to change ?
    Edinburgh
    stalk very easy, takes 10 secs. Pull old stalk out, shove in new one. Spring was easy too. A bit of a pain to get old one out but 2 mins to put new one in.
    Blantyre
    Quote Originally Posted by Big Knox View Post
    Sooooooooooooooooooooooooooooooooooooo
    Where are the HOW 2's
    11 Post(s)
    I thought you had to slide a paperclip down the side of the stalk through a small hole to release the locking clip?
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    my clutch does'nt have a spring under it,if i bought one would it be a direct fit coz im having trouble with my cc when i lift the pedal up it stays on.p.s were can i get one and how much. cheers
    May 2008
    Tyneside
    Quote Originally Posted by luke.oldham View Post
    Here's a link with part no price and piccies http://www.vectra-c.com/forum/showth...=clutch+spring
    Aug 2009
    Quote Originally Posted by tridley View Post
    thats spot on mate,thanks for that.cheers. luke
  1. ongoing additions
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 20:25
  2. Z22YH Problems Ongoing??
    By Mr_Chips78 in forum Engine & Drivetrain
    Last Post: 6th November 2010, 17:34
  3. Ongoing problem - P0340
    By Ste in forum Engine & Drivetrain
    Last Post: 4th December 2009, 13:01
  4. My ongoing leak saga...
    By TrevF in forum Bodywork & Interior
    Last Post: 10th March 2009, 12:31
  5. Ongoing saga
    By v6boy in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2006, 19:26
vectra cc problems
