Thread: Oh No........
    Regular Member Whisky's Avatar
    Mar 2011
    Kirkcaldy/Barrow-in-Furness
    Unhappy Oh No........
    I've been looking into this "earthing" problem and my rear O/S indicator not working, and I really hope it aint the ECU!! It is only one light and the bulb defo works because i tried it in the other side.
    The indiactor doesn't light when the hazards are on either, so that rules out indicator stalk and/or possible relay problems.
    Is there any way to check this without Tech 2, i.e. doing the ignition and acc/brake trick??
    This could be a very expensive problem, I hope not..........
    are you sure its not the housing unit that the bulbs clip into
    best bet is to find someone with a similar car and try there light unit in your car
    Mar 2011
    I've jumpered out from one of the side lights to the input side of the pin and the indicator bulb lights up so no idea whats going on.........
    Mar 2011
    Took the car for a spin last night,no probs with the indicators now and all is well,looks like an ECU reset was all that was needed. Well happy that i aint looking for a replacement ECU now!! Hopefully it was just a floating earth thats sorted itself, we'll just have to wait and see if it rears its head again.
    Sodding Typical on Sea
    Good man great result!
