Thread: bad starting
    Apr 2011
    co durham
    Default bad starting
    i bhave a 03 signam 2.0 dti starts ok cold starts ok hot but that bit in the middle is a problem. if i go on a short trip then let the car stand ,it is very hard to start,when it does start iget alot of white smoke,anyone know the fault
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Sounds the same as my old Dti check out my threads there's loads of posts and there's a video if it's the same as mine a new battery and starter cured it .
    Irmscher Insignia CDTI 130
    Apr 2011
    co durham
    i have fitted new battery still the same fult
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Would help telling us what the bad starting problem is or if you have explained this before in another thread maybe you should of posted there instead of making a new thread ?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Threads merged
    If battery didn't solve problem it's a process of elimination now eg: Starter, leak off pipes, glow plugs, GP relay, crank shaft sensor
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by bigmac View Post
    Threads merged
    If (like mine) it starts fine from cold, better in fact, then surely that rules the glowplugs & relay out? Leak offs next, then the starter as they're not that expensive either;
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_629wt_1066
    Although a while ago bigmac did mention it's bit of a pig to actually change, that's why I've not done mine yet lol.
  1. Not Starting
    By mungo1985 in forum Engine & Drivetrain
    Last Post: 11th September 2012, 21:52
  2. Not starting..... Possible Starting Motor
    By portreathbeach in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2012, 11:30
  3. Starting on 3
    By keefy*2010 in forum Diesel Engine related
    Last Post: 15th January 2011, 03:09
  4. EML flashing when starting but not starting (Vec-B)!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th July 2009, 15:51
