Results 1 to 10 of 20
Thread: my 2004 vectra estate 1.9 cdti 150 kicks out alot of blue smoke after driving for 6-10 miles
    Regular Member clintton's Avatar
    Apr 2011
    kent
    Default my 2004 vectra estate 1.9 cdti 150 kicks out alot of blue smoke after driving for 6-10 miles
    can anyone help my 2004 vectra estate 1.9 cdti 150 kicks out alot of blue smoke after driving for 6-10 miles the i have to stop and just let the engine tick over and it stops smoking then i carry on my journey then again after 6-10 miles it starts smoking again
    i have had the inlet manifold stripped cleand & desooted same again with the egr valve & a new turbo fitted but the smoking is still there can any one help as im now getting to the point where i will end up srapping the car
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    why did u have a new turbo fitted and when?
    Regular Member sebadee's Avatar
    macclesfield
    Have u checked all pipes for splits
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    It sounds like your dpf is regeneration to me on your drivers door plate have a look you will have a number like 0.5 in a little box on the bottom left of the sticker
    Apr 2011
    kent
    Quote Originally Posted by daveypower View Post
    had new turbo because my garage said i was the oil seals in the turbo causing the smoke
    Apr 2011
    kent
    Quote Originally Posted by winnie2457 View Post
    just looked an there is a box with 0.50 in it
    Regular Member owengh's Avatar
    Feb 2011
    Wolverhampton
    The Diesel Particulate Filter of DPF will clean itself every so often and in order to do this it superheats the DPF to burn off all the excess soot. Whilst it is doing this blue smoke eminates from your car and everybody stays clear!! As I understand it is normal and you just have to continue to drive, preferable in an agressive manner, until it has finished. Normally takes 10 to 15 mins to complete depending on stlye of driving. I know as have the same issue in my Zafira but it ended up replacing the DPF (£1200) and then 6 months later a regen from VX before I eventually was told the truth!!!
    Mar 2011
    Donegal
    also man if your turbo seals did go before, there will more that likely still be alot of oil getting burnt out of pipe work/ intercooler and cat/dpf, but if its just started all of a sudden and not straight after a turbo replace, then what owengh says sounds about right
    Apr 2011
    kent
    Default link to video of smoke on idel
    Antwerp, Belgium
    what do you mean by tickover?
    try to drive 30 km and see if he still has it
    if it is your dpf then it wil burn empty
  1. my vectra estate 1.9 cdti 150 blue smoke after driving 6-10 miles
    By clintton in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2015, 09:03
  2. alot of smoke from exhaust on my bro`s 1.9 cdti 130
    By chris6409 in forum Engine & Drivetrain
    Last Post: 24th November 2010, 21:38
  3. is 100k alot of miles for the 1.9 cdti 150??
    By dog in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2010, 07:39
  4. Vectra C (2004 1.9 cdti) black smoke, no turbo, air leak HELP!
    By baldieone in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2010, 20:54
  5. Vectra C (2004 1.9 cdti) black smoke, no turbo, air leak HELP!
    By baldieone in forum Vectra C / Signum Troubleshooting
    Last Post: 29th July 2010, 13:51
