Results 1 to 2 of 2
Thread: Advice please Signum 2.0 DTI ratchety engine noise, and squeek..!
    dudley
    Default Advice please Signum 2.0 DTI ratchety engine noise, and squeek..!
    right I have a squeek coming from the drivers side area of the engine bay, which happens when the engine is switched off, it's doing it every time the engine is switched off. I have searched and aux drive belt or/and tensioner seem to be the best bet (do you agree),
    also, I have a noise coming from the engine, not sure if it is meant to be there or not, i have only just recently noticed it after I removed the under tray and sound proofing, the noise is like a ratchet being turned, and it increases with engine speed, (in neutral and while driving), I have searched youtube for chain and tensioner problems, piston slap, rod slap, tappetts, big end knocking and associated engine noises but nothing comes close, its a constant regular noise but only when the engine speed increases, no noise on idle, any ideas....? could this be related to the aux drive belt tensioner...?
    Im stuck with it at the mo, no going to vauxhall, it cost me £700 january for a clutch and flywheel and I don't really have the money for more problems,
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    well as the sound isint there on idle but is there wile the car is in neutral, and it increases with engine speed and neutral speed. when you removed the under covers maybe you left somthing catching an a drive shaft or the tyre, could be something as simple as that, but id be more inclined to think its not and engine problem but a drivetrain problem.
  1. 2.8 engine noise help
    By Mogsy007 in forum Engine & Drivetrain
    Last Post: 6th January 2013, 22:34
  2. squeek when switching engine off
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2010, 10:00
  3. Replies: 3
    Last Post: 28th April 2009, 19:49
  4. Squeek from 2.2 direct engine - anyone else suffer?!
    By Maddog1974 in forum Engine & Drivetrain
    Last Post: 26th March 2009, 17:28
  5. 3.2 Making a Squeek noise when i start it/rev it
    By bigstevex in forum Engine & Drivetrain
    Last Post: 14th November 2007, 15:37
vectra c 2.0 dti engine noise
