Results 1 to 10 of 11
Thread: A.R.B Bushes
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default A.R.B Bushes
    Anybody Thats Fitted The 25.2mm A.R.B Bushes To The Front Of There Vec..Noticed Any Gaps..Or Did They Close Right Up Without Being Tightened ?
    Regular Member Jezzy's Avatar
    S.E
    There was definitely a gap on mine before I put the bracket on, and IIRC there was still a small gap after I'd tightened the bolts.
    It's not a gap that you have to worry about though - if you've bought the largest size bush available (25.2), then you know that it can't possibly be the case that your ARB is too big for the bush. It would be much more worrying if the bush seemed to be too big for the ARB, because then you'd think you should have bought a smaller size.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Tam with yours being a 1.8 non sports I think you've bought the wrong bushes
    exeter
    there should not be a gap . there are 2 size arbs . when you put the bracket back on it should be a tight fit and close all gaps . you got to have the right size . look on the old ones it will tell you the actaul size
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    iirc the fronts don't have the size on them only the rears. The fronts should have the vx part no though
    S.E
    "1.8 non sports" implies that he would have the smaller diameter ARB, but his issue is that the ARB seems too big for the largest bush.
    Aug 2010
    Dundee-Motherwell
    Got 16/17/18 For Rears...24mm For The Front (Didnt Have 25.2 In Stock)..Took Rears Off..Clearly Marked 17..Changed Them Over..Problem Solved...Tried The 24`s On The Front..The Gap In The Bush Was BIG..So With It Being Sunday..Went To Local Factors (Autosave) They Ordered 25.2``s For Me..Went Out..Jacked Car Up..Slid It Over A.R.B..
    Still Same Gap.Guy Even Measured My A.R.B...Argued With Guy That They Aint 25`s lol
    Went To Stealers Yesterday..Ordered 25`s From Them..Think They Should Be There This Morning..The Size Of The Gap I Would Say Dont Look Far Off Half An Inch..
    Now When It Comes To Tightening Them Up..I Dont Think Bushes Are Gonna Close Up That Much..Torx Bolts Nearest Engine Will Be Tight..Its The Bolts Nearest Bulkhead..Gotta Use A Ratchet Spanner..Get 1 Click..Take Spanner Off And Click It 4 Times With Finger..Put It Back On Torx To Get 1 More Click
    Anyways..Will Let You Know How I Get On..Cheers Guys
    Fronts Aint Got Size On Them..Just Part Number..According To Vauxhall Yesterday..My Old Ones Are 25.2..
    Regular Member Innes's Avatar
    Plymouth
    I had my bushes fitted by my local garage. I noticed one had a slight gap in it and asked about on this forum and the gist wast that it's ok to have a bit of a gap. Here's a pic of mine to show you.
    Aug 2010
    Dundee-Motherwell
    Finally Got Hold Of The Correct Bushes..Think It Was A **** Up With The Local Factors..1 Of The Bolts Was A Pure ******* Though..But Finally Done
    Gonna Attempt Banana Arms Tomorrow..Think I Can Probably Make It A 2 Day Job lol
    Cheers Peeps
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    Mine were definately right size and there was still a little gap like in picture. I wouldn't worry.
  1. A.R.B Bushes
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 16th April 2011, 21:39
  2. arb bushes
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2011, 09:51
  3. ARB bushes
    By Marcosuk in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 00:29
  4. arb bushes
    By deeks in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 14:54
  5. Replies: 5
    Last Post: 21st March 2010, 12:34
