Results 1 to 10 of 23
Thread: spanner symbol advice
    Regular Member bunsen1's Avatar
    suffolk
    Default spanner symbol advice
    hi guys, went out this morning but before i got 50 yards down the road i noticed the spanner symbol on, so i stopped instantly and turned off, turner on again and no spanner symbol, didnt notice after my next stop but then we took my little sister prom dress shopping, didnt notice it after a couple of stops more, but then after this it was there when keys in ignition but not after start up,
    anyone got any ideas, skint at the mo and dont need this, i have no code reader and i do believe on the 54 reg sri 150 that no fault code can be found with pedal test
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Bunsen
    if light goes off after a few seconds VX don't advise worrying about it.
    suffolk
    hi mate, its why it first came on thats the original worry, but guessing its just ones of those things as at no point was there a loss of anything at all
    will it clear itself then mate?
    If the engine is not going into safe mode and the warning light goes out after a few minutes, then it is most likely glow plug failure
    suffolk
    hi mate, no safe mode and light goes of as soon as car is turned over so its not even a few minutes? whats price wise if was to be glow plug, any idea
    Jul 2009
    Engine : 20 Dti
    usually turns out to be glow plugs as M8 says bud no worry
    if money is tight no need to do anything untill winter and then you may find it starts Ok
    suffolk
    thanks guys, just checking the bay, is diy job for noobs?
    Jul 2009
    Engine : 20 Dti
    NOt a bad job sometimes they are a pig to pull out,there is a tool but it's a fancy deep socket 9mm i think but not 100%sure,someone on the site will know for sure,it's been a long time.
    West
    if it does it on cold morning starts only, then it's very likely to be the glow plugs... tomorrow if it does it again don't reset it... just drive it & it should go out once the car has a warmed up a little.
    glow plugs are £10 each ish + vat & simple to do
    hth
    suffolk
    not had it before today, car starts better cold from what i may have noticed
    how would you reset it? i have no code reader
    was warm today round where i was
    £19.14 from euro car parts for a set of 4
  1. car/spanner symbol
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2012, 09:00
  2. Spanner symbol up???
    By PeterVV in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2010, 22:43
  3. car and spanner symbol
    By raddish in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 12:31
  4. Car symbol with spanner
    By jeffcapes082 in forum Engine & Drivetrain
    Last Post: 1st June 2009, 22:52
  5. car symbol with spanner
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2008, 21:53
