Thread: Tyre valve bust...going on hols tomorrow!!
    Regular Member marky2027's Avatar
    Northumberland
    Unhappy Tyre valve bust...going on hols tomorrow!!
    Typical. Had lush day in garden, bbq,wine etc. Going away for a few days first thing in the morning and so I thought I would give the tyre pressures a quick check. Got to the last tyre which needed a little top up and when I took the foot pump off the valve.......ssssssssssssssssssssssssssssssssssssss sssssssssssssssssssss... The valve stem nipple thing inside was just flopping around. After a few seconds of shouting F*%k!!! I quickly had to move the car off the drive as it's a tad steep. Got the space saver on now and will have to sort it first thing. Of all the times for it to happen and i have checked them loads of times. Has this happened to anyone?? Will the whole valve stem have to be changed or do they just screw those nipple things in from the outside with a special tool?
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Sods law hope holiday goes better
    Irmscher Insignia CDTI 130
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    theres a thing that just undo them from out side like when they change tyres
    Northumberland
    Couldn't believe it!! May be I was a bit rough removing the foot pump from the stem. We drive to France every year on holiday....glad it's happened now really coz I am paranoid about checking the tyres when we drive any distance. Off to York tomorrow and it's only an hour and a half or so. Kwik fit opens at 08.30 tomorrow.
    Sep 2010
    in a box
    yes mate there do it for free id say or tops a fiver if they ask more tell um stick it as there like pennys for a big bag and there thing they use anyone can buy them so dont let them do you on that hope your hols go well mate dont forget water oil tyres and the like to check
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    have you tried tightening the inner up it might have come loose if you check them that much
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Had exactly the same on my left rear the other day....
    ... coming out of work I thought the rear looked a little wonky so checked the pressure .... 7 psi !!
    Got home slowly and pumped it up with footpump.... except it wouldn't go over 20psi. Then as I took the hose off...sssssssssssssssssssssss.
    A little wiggling and I found the valve stem had split just at the base of the brass thread.
    Spare alloy (different thread ) fitted and off down to my local National. £10.50 later, new valve, tyre re-fit and balance. Safe again.
    Northumberland
    Quote Originally Posted by markj23 View Post
    Yes mate tried that but the larger flat brass piece across the bottom will not budge. The nipple is pushed down and has no "spring" in it so it doesn't spring back.
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    if its the valve why not change em yourself, i always keep a few spares at home
    Northumberland
    Well I'm all sorted. Waited 20 minutes and then it took 20 seconds to unscrew the valve put new one in and check for leaks. Plus he didn't charge me. Result!
  1. How much to get a new valve fitted on a tyre.
    By connery-sri in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 12:52
  2. Help - Tyre valve
    By a1ant in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2010, 19:39
  3. Replacing tyre valve ???
    By Bainie in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2006, 19:45
