Thread: Water
    Mar 2011
    Cleveland uk
    Default Water
    Hi guys need some info pzl
    I have seen a small pool of water just under the drivers headlight about 2" wide ? Is it just the air con ?
    Mar 2011
    Cleveland uk
    Anyone know wats up then ?
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Mine are dropping from middle of car near centre console if ac on.
    11 Post(s)
    Is it plain water, or does it look like it's got coolant in it? Coolant should stain whatever it comes into contact with.
    What does it taste of?
    11 Post(s)
    If it's antifreeze/coolant, don't drink too much of it.
    http://www.telegraph.co.uk/news/ukne...ning-wife.html
    Mar 2011
    Cleveland uk
    Me thinks its just plain water if that helps
    Mar 2011
    Cleveland uk
    It could be this ?
    X18XE1 engine...the common leak is the front pipe that goes from compressor to connection at nsf corner behind front part of subframe, and also goes from compressor to connection near osf top corner of rad. the leak is nealry always from the hiddine joint underneath the silver shrouding on the downward part of the pipe from compressor, cuttin the cover with snips can help to spot any tell tale marks...to the naked eye, a snail trial is left, only slight....to the ultra violet...white deposits...
    Mar 2011
    Cleveland uk
    Anymore help guys ?
    I think i'll drink the entire contents
    Quote Originally Posted by Denbo View Post
    If your not loosing any fluids and your using the a/c a lot its probably that.
    Is it still there if you don't use the a/c?
  1. water water everywhere
    By rob warrington in forum The 'Off Topic' room
    Last Post: 9th December 2012, 00:03
  2. water and oil
    By Tinks in forum Engine & Drivetrain
    Last Post: 16th February 2012, 19:40
  3. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  4. help.........water!!!
    By lilangel in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2008, 10:49
  5. Water water everywhere!
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2007, 15:09
