Thread: What's up with my car
    Regular Member craigmerry's Avatar
    Jan 2008
    midlands
    Default What's up with my car
    When i first start it up it turns over for ages then starts with a puff of white smoke. Once started it will turn over fine until it is left for a time. I've changed the glow plugs and the plug pre-heat censor/timer thingy. Any ideas
    Jan 2008
    midlands
    Oh yeah, 2.2 dti
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    My gues is the fuel is flowing back when parked up. Common issue on the 2.2. Someone with a current 2.2 will tell you what part you need as its some time since I had mine
    chesire
    i think that the fuel leaks back to the tank on a dti !. have a search on the how 2s there might be something to fix it on there hth...
    West
    check the leak off pipes, search forum as there's plenty of posts about them
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Park it facing down a hill if you can overnight and see if it starts up first time. Mine does this now, leak off pipes could do with being changed. Failing that, injector seals.
    Jan 2008
    midlands
    Thanks everyone, will have a look this week.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    mine does the same man , im guessing injector seals but i cant get anyone to look at it for 3 - 4 weeks have you tried starting it with the water temp switch disconnected (which brings on the glow plugs ), i have put a witch inside the car from the temp switch and it does help but it,s not the cure
