Results 1 to 2 of 2
Thread: Throttle body question
    New Member Loftuz's Avatar
    Nov 2010
    Wisbech
    Default Throttle body question
    This morning I removed my throttle body on my 2.2 Vectra Z22SE. For a while now it has not been running great, feels slightly hesitant a low RPM and generally lumpy. Iíve tried new plugs, new coil pack, blanked off the EGR and done a lot of head scratching. Being a fairly naive when it comes to all things mechanical Iím not sure if my TB has had it. Once I took it off I noticed that the butterfly flat does not close all the way. With your fingers you can push it one way to full close it by about 30 degrees and the other way at around 180 to fully open it. Should it be fully closed or is this normal?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Thats normal mate, you need that little gap to let air in for idle as the z22se has no ICV. If this gap area is dirty, both on the butterfly and barrol then it can cause poor idle.
  1. Throttle body question
    By McLovinH in forum Engine & Drivetrain
    Last Post: 28th August 2012, 22:01
  2. throttle body question
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 16th January 2011, 16:51
  3. Question about electrics on throttle body
    By jsud2002 in forum Engine & Drivetrain
    Last Post: 8th October 2010, 19:41
  4. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
  5. Throttle body question
    By sirnapper in forum Engine & Drivetrain
    Last Post: 8th August 2009, 14:35
