Thread: uneven tyre wear on rear
    Apr 2011
    carlisle
    Default uneven tyre wear on rear
    i have a 1.8 16v vectra breeze 2005 standard no mods at all tyre size 215/55/16 they are wearing the inside of both tyres what could the problem be...............
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    This happened on my 2003 SRi DTi. Exactly as you describe. It was way before I got the car. I know the previous owner, just advised her to get two new rear tyres and an alignment check. Alignment was only millimetres out, this was sorted, and 21k miles later, the tyres are fine too
    Also check the rear shockers and springs too
    Make sure it is a full four wheel alignment check, that includes the rear camber
    Have this performed at next tyre renewal
    How long have the rear tyres been on the car?
    West
    Do have a rear knock?
    check the rear upper control arms
    Nov 2009
    Warwickshire
    I would like to thank all the contributors on the thread. Following your tips has helped me and I hope it may help other members with a similar problem to pass on how I got it sorted.
    My model is a 1.9cdti 120 estate and the problem was - steering wheel off level - car pulling to the left - with uneven wear taking the inside edge tread off both front tyres and feathering on both rear tyres.
    First the guys are right - don't waste your money a basic front wheel tracking at a tyre depot. Pay the extra and get a four wheel alignment with a specialist firm that use a 'Hunter' laser. My original Vauxhall springs had been replaced with Eibachs and being 30mm lower I was concerned about what settings they would use for the laser set up. But m8internet's technical know-how reassured me and just as he said the computer adopted the 'sport suspension' set up.
    The diagnostic found my problem was caused by front wheels out on toe and rear wheels out on toe and camber. The reset to spec has given me a level steering wheel and a car that now drives to a straight line. The total cost was £80 but worth it for the transformation to the car's handling and hopefully I should save that with better tyre wear. Thanks again to all the members who share their technical knowledge on the forum.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    i had mine done with the hunter system last week... the cars improved loads and economy is up so im happy...
    very clever and ultra accurate machine!
    al.
    Sep 2009
    Audley STAFFS
    yes my rear tyres wore down on the inside,, new rear upper control arms ,,,, sorted.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    rear inner tyre wear is nearly always caused by rear upper control arms. Simple check to do and here is a video showing you http://www.youtube.com/watch?v=h-LF-qQY-Lc
    There should be no movement when you do this check
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Stand well back from the rear of the car, I wouldn't be surprised if the rear wheels have too much negative camber (wheels point in at the top).
  1. uneven and serrated rear tyre wear
    By veclee in forum Suspension, Wheels & Brakes
    Last Post: 3rd December 2012, 02:28
  2. Strange uneven rear tyre wear!!
    By maximus8425 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd October 2011, 09:40
  3. REALLY uneven tyre wear
    By Celes in forum Suspension, Wheels & Brakes
    Last Post: 21st November 2010, 23:25
  4. Uneven Tyre wear
    By Manni2375 in forum Suspension, Wheels & Brakes
    Last Post: 23rd July 2007, 15:19
  5. Major Uneven Wear on Rear nearside Tyre
    By jamieclarke in forum Suspension, Wheels & Brakes
    Last Post: 7th June 2007, 19:22
