Thread: Signum Auto Gearbox - Advice
    Nov 2010
    North Yorkshire
    Vehicle : Signum Elite 1.9 CDTI
    Engine : 1.9 (150)
    Mileage : 113.000
    Default Signum Auto Gearbox - Advice
    Today the Signum, a 2006 1.9, caused me a little concern when on three occasions on pulling away from a standstill at road junctions it seemed to not select the second gear immediately, the engine raced for an instant, then it found the gear, gave a bit of a clonk, and then everything went as it should from there.
    This is the first time that it has happened, and it didn't happen every time and I'm a little concerned about it. I have driven the car for 200 miles today and apart from these three incidents, it ran perfectly.
    Any thoughts and/or advice would be appreciated.
    Regular Member Jezzy's Avatar
    S.E
    There are pretty much only two things you can do to improve an auto transmission's performance, other than spend hundreds/thousands on having it rebuilt or replaced. Those two things are
    a) Ask your dealer if there are any software updates that your car needs
    b) Renew the transmission oil.
    Dealers don't like doing the second one, and will tell you that there's no specified interval for changing the gearbox oil, but those that have ignored their dealer and done it anyway have often found that it cures the problem. The cynical amongst us could say that dealers would prefer that the problem was left alone until it warrants replacing the gearbox, as this is far more profitable for them, whether the customer pays or Vauxhall pays under a warranty.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as Jezzy says upgraded softwear was updated in may 2006.
    Nov 2010
    North Yorkshire
    Engine : 1.9 (150)
    Mileage : 113.000
    An update, by the way thanks for the advice, the car is in this morning for a gearbox oil change even though the problem has not reoccurred. Better to be safe than sorry.
    One other point, will gearbox problems show up as fault codes and is it controlled by it's own control unit?
    Nov 2010
    North Yorkshire
    Engine : 1.9 (150)
    Mileage : 113.000
    Oil change done at £45.00 - not bad. It seems fine and the problem has not reoccurred since the initial glitch - I'm touching wood as I write this, mustn't tempt providence.
    Nov 2010
    North Yorkshire
    Engine : 1.9 (150)
    Mileage : 113.000
    An update. Following Jezzy's comment I contacted my local VX dealer and they updated the software - they commented that there are instances of my problem being caused by wear to the valve body on early facelift cars that was sorted out in 2007 by fitting an upgraded valve body.
    My immediate thought was, if they have fitted a "duff" part, surely it is up to VX to replace it if it becomes defective.
    I don't know whether there is only one valve or one for each gear.
    Regular Member poves's Avatar
    lancashire
    After having the autobox fail on my v6 a while back , my advice would be - try and take out a warranty on it , just incase it goes bang .
  1. signum 2.8 auto gearbox
    By viper8 in forum Engine & Drivetrain
    Last Post: 3rd June 2012, 21:05
  2. signum 2.8turbo auto gearbox
    Last Post: 29th December 2011, 18:54
  3. Signum Auto gearbox issues
    By fastcarmanaic in forum Engine & Drivetrain
    Last Post: 22nd July 2011, 11:02
  4. change gearbox oil on auto signum
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2010, 15:41
  5. Signum auto gearbox
    By Signum Dek in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 21:59
