Thread: Door moulding
    Regular Member connery-sri's Avatar
    Basildon, Essex
    Default Door moulding
    How do you remove the door mouldings/bump strips from the doors once the door cards are off?? Just wanna know what I am up against before I remove them for painting!!
    Cheers.
    Oct 2006
    southampton
    15 Post(s)
    pretty sure they are stuck on but some have mentioned locating pins too...
    Regular Member Jezzy's Avatar
    S.E
    Stuck on with double sided tape all the way around, with wider strips at each end, plus clips at each end as well that need to be compressed from inside the door skin, plus locating pins about one third in from each end.
    [Ex]Admin Duncan's Avatar
    but if you don't want to take off the door card then you can ease off as much of the strip as you can and try and carefully get a pair of pincer nose pliers between the strip and the car and squeeze the barbs of clips so that the come out of the hole in the door. Other option is to just use a bit of brute force and pull the clip through the hole. A barb will probably break off but no big deal as it doesn't really need it. When you put the strip back on, with a new bit of double sided tape on it, it won't be going anywhere. Not sure why they even have the clip there in the first place.
    Engine : 1.9 CDTi
    The clip is more a locating lug so they are fitted straight I think.
    Basildon, Essex
    Cheers lads. Will get them off tomorrow with a bit of luck. See how long it takes me to paint and refit them!!
    Basildon, Essex
    Took the softly softly approach on the near side, removed the door cards etc. Drivers side was a different story. Couldn't get the wiper winder off the rear door so just did as Duncan said and pulled from the outside. Now to prep and paint!!
    Basildon, Essex
    Please with my progress so far. All door mouldings are prepped ready to be primed in the morning. Also managed to remove, prime and do 2 coats of paint on my boot strip. Oh, not to forget I also removed my colour coded side repeaters, sanded them down, clear primed them and gave them one coat of paint too!! Looking forward to the results!!
    Oct 2006
    southampton
    15 Post(s)
    Quote Originally Posted by connery-sri View Post
    Keep us posted with pics matey, we all love pictures
    Basildon, Essex
    I will see how far I get tomorrow and possibly post some pics in the evening.
    Cheers.
  1. For Sale: Facelift opel V Grill moulding (panacotta)
    By scotty84 in forum Parts for sale
    Last Post: 16th August 2011, 17:48
  2. Drivers Door moulding trim
    By Bloicy 3.2 V6 GSI in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2011, 23:19
  3. Door Moulding-What to sitck on with??
    By Vaux-Man-G in forum General Chat
    Last Post: 27th October 2009, 21:47
