Results 1 to 2 of 2
Thread: Lighting board problems
    Aug 2010
    Altrincham
    Default Lighting board problems
    Hi All
    I have a 2004 vectra and have (today) tried to install a halfords lighting board as I want to use a cycle carrier.
    Along with the lighting board I bought the Halfords lighting board wiring kit which sadly didn't come with instructions but with a bit of searching on this forum have managed to find some.
    The wiring kit comes with a TEB7AS 7 way bypass relay which i have fitted.
    The LHS flasher works.
    The RHS flasher works.
    Both side lites work.
    Both break lights work.
    The problem is that if I have the indicator on and press the brake then 'sometimes but not always' all the lights go off and then sveral seconds later come back on.
    This also occurs if I have the side lights on and press the brake lights.
    Any suggestions?
    Best regards
    Steve
    Aug 2010
    Altrincham
    Problem solved!
    To test the unit i had taken a live feed from the boot light.
    I suspect that this was not able to supply enough current to drive the relay unit and the lights on the board.
    After taking a live feed direct from the rear fuse box all now works!
  1. Is the cd70 pcb circuit board coded as in a need a new board
    By gurjsagoo in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 00:07
  2. Board Computer
    By sol in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2010, 22:27
  3. dash board.
    By delboy2028 in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2010, 20:22
  4. Board
    By jambo114 in forum The 'Off Topic' room
    Last Post: 29th July 2008, 15:26
  5. On Board Computer Problems.....
    By Signum_CDTI in forum Electrical & ICE (including SatNav)
    Last Post: 23rd November 2007, 02:45
