Thread: Vectra 2.2 Direct vs cam chain
    Regular Member Peabrain's Avatar
    Apr 2008
    Purmerend (Holland)
    Unhappy Vectra 2.2 Direct vs cam chain
    Brought my 6 year old (51000 miles) Veccy to de dealer last week to replace a defective CIM module which set me back for around 250 euros. He phoned me the same day and told me that he had heard a slight rattle while starting the engine which idicated that the chain had to be replaced. Chain replaced ? I thought these things should last a lifetime ?
    Not with the 2.2 he told me and after reading the forum and the z22se website I know better. The 2.2 has some issues
    Repair is scheduled for coming Tuesday and will cost me around 1000-1200 euros. For that they replace the 2 chains and the tensioner for one from a turbo engine.
    Do you guys (and girls) have any experience with this ? Is this the right way to go at it and will this solve the issue forever ?
    The told me that Opel won't pick up anything from the bill because the car is older than 5 years but since this is clearly a tear and wear issue in my opinion it has more to do with milage that age. Any off you has any experience about how Vauxhall handles these issues financialy ? Thanks for your input.
    13 Post(s)
    Tensioner failed on mine. Vauxhall footed 70% of the repair bill for a new chain and tensioner they fit to the 2.0 turbo engine. The balancer chain wasn't replaced on mine. That hardly goes wrong apparently.
    http://www.vectra-c.com/forum/showthread.php?t=104735
    The balancer can also be deleted with a specific kit if required to free up a few more horses...
    Apr 2008
    Purmerend (Holland)
    Well, no luck with Opel. They are only willing to contribute when the car is < 5 years and mine is 6. Set me back 800 euros
    Regular Member Sambor's Avatar
    Elgin
    Do not forget replace water pump(if need it).Is running under small chain.
  1. 2.2 Direct Chain
    By spennny in forum Engine & Drivetrain
    Last Post: 31st July 2012, 19:36
  2. Chain Tensioner 2.2 Direct
    Last Post: 12th October 2011, 12:51
  3. timing chain on 2.2 direct 05 plate vectra
    By mani2002uk in forum Engine & Drivetrain
    Last Post: 26th October 2010, 20:09
  4. Timing Chain 2.2 Direct
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 15th January 2009, 10:59
