Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Air con not working.
  1. #11
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by veccy c owner View Post
    i recently bought a 52 plate vauxhall vectra and the dial for adjusting the heatings strength
    has been pulled off it turns all the way around (is this supposed to happen) and the blower
    is not working althougth when i turn on the quick clear windscreen it soon heats up the car so cannot be a blower problem but i would like this fixing as it is quite inconveinint is it a case of replaceing the control dials or something else any ideas?
    You first need to establish whether the fan is working, by whether you can hear it, regardless of temperature. Hot air is a sympton of a working heater, not a working fan.
    Secondly, there's a common fault that causes the fan to not work on speeds 1-3, but work on speed 4, which would mean that the fan will work on the "quick defrost" setting but not on any other setting. If this is the case, it's usually caused by the drain hole in the engine bay, in front of the pollen filter, being blocked, which causes water to get through the filter into the fan housing. There's a green relay under the glovebox that will need to be replaced to get the fan working correctly again.
    Your heater controls also seem to be broken, but it's easy to swap out; just make sure that the replacement looks identical as there are at least 4 different types available.
  2. #12
    Here is one way to prove it
    Switch the fan setting to off
    Turn the airconditioning to off
    Switch all the vents to closed position, then leave one open
    Turn the engine on
    Turn the airconditioning on
    By default the fan commences at position 1 (even in the off position)
    If there is no difference, the fan has failed
    Ultimately you may need to replace the control panel, as the switch is integral to the control panel
  3. #13
    Quote Originally Posted by Bigtee View Post
    No and i didn't in the Astra before yet that worked ok.
    I'll get it in asap, do you know the cut off mileage for warranty i think it's 60k?
    Im just on 12k so lots to do yet.
    Oooo sorry, i was just trying to establish if it had been used or not to keep the seals lubed up. if its not been used and then didn't work i thought it maybe a higher chance of a gas leak through dry seals, rather than it worked yesterday but doesn't today which would make me think its possibly a stone hole in the condenser. 60k or not its not covered for damage like a hole.
    Hopefully for you its not as that won't be covered under warranty.
  4. #14
    I've argued this one before, initially refused but decision reversed plus the gas was included
    The argument was that unlike a tyre which is permanently in contact with the road and subject to wear and tear, the condensor itself is not
    Equally, the condensor is not covered by comprehensive car insurance policies and so can only be covered by vehicle component insurance (warranty)
    Seems they didn't want to respond to that!
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Working out MPG
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2011, 10:51
air con not working 58 plate vectra
