Results 1 to 10 of 14
Thread: Air con not working.
    Aug 2010
    Leeds
    Default Air con not working.
    58 plate vectra so still in warranty do these have a common problem as it's not cold and i don't think there's any gas left no cooler than air temp.?
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    I would try a re-gas at kwik-fit first,it may just be too low on gas to work.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Or at dealership as still in warranty errr, as it will be free
    Full Member Big Sig's Avatar
    Have you used it as your supposed to over the winter?
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by John C S View Post
    I wasn't aware or didn't even think about the dealers doing it for free,that's a much better option
    Aug 2010
    Leeds
    No and i didn't in the Astra before yet that worked ok.
    I'll get it in asap, do you know the cut off mileage for warranty i think it's 60k?
    Im just on 12k so lots to do yet.
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by Bigtee View Post
    That's very low mileage,there are loads of things to get fixed yet then
    Aug 2010
    Leeds
    Quote Originally Posted by Aikon58 View Post
    Thats what im thinking..................
    Apr 2011
    United Kingdom
    i recently bought a 52 plate vauxhall vectra and the dial for adjusting the heatings strength
    has been pulled off it turns all the way around (is this supposed to happen) and the blower
    is not working althougth when i turn on the quick clear windscreen it soon heats up the car so cannot be a blower problem but i would like this fixing as it is quite inconveinint is it a case of replaceing the control dials or something else any ideas?
    The airconditioning gas is not covered under warranty, termed as a wear and tear item, as the system has normally suffered a leak
    However if the cooling system, pipes and/or radiator has failed then the gas would be included
    I would suggest asking for a quote for regas from both a local mechanic and the dealership, just in case the warranty claim is refused
    You can then decline the dealership repair and go elsewhere
    Equally, most dealerships use a contractor, very few do it themselves
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Working out MPG
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2011, 10:51
air con not working 58 plate vectra
