Thread: windscreen wipers & washer not working properly
    Apr 2011
    swansea
    Exclamation windscreen wipers & washer not working properly
    Hello to all, I am new to the site but have viewed the forum a lot. I have an issue with with my Vectra C SRI 2.2, 52 plate, my front wipers and washer? the front washer doesn't work but the rear does? and the wipers when I press down for 1 wipe, works but when you let go of the stalk the wipers stop immediately, also when you push up once for intermittent they go to continuous wipe and take ages to deactivate?
    Does anyone have a solution? I have been told it could be the relay??
    regards Bootneck85
    Regular Member dannydm1's Avatar
    Jan 2008
    leeds / wakefield
    comman problem.... mine did this, but only when cold.... there is in the "how 2" section a diy fix for this.
    Jan 2008
    leeds / wakefield
    Apr 2011
    swansea
    Default wiper problems
    Awesome danny thanks for the link and advice!
    regards bootneck85
    Feb 2015
    Southampton
    Vehicle : Vectra 1.9 CDTi Exclusiv
    Trim : Blue
    Engine : 1.9 CDTi
    Mileage : 66,500
    Quote Originally Posted by bootneck85 View Post
    regards Bootneck85
    I am new to the forum too, registered today because I found exactly the same problem with the wipers on my 2005 Vectra.
    Only had it a month, bought it from a dealer too, and this is the 2nd fault I have had on it (the thermostat stuck 2 weeks ago).
    Fortunately I have a 3 month warranty from the Vauxhall dealer, but I wondered if this problem is temperature related?
    The dashboard was showing -1.5C when I started the car up at 7am, so not outside of the levels that the car should be designed for. But as soon as I went to wipe the screen I noticed that with the once-off wipe the wipers stopped as soon as I let the stick go, and the intermittent set the wipers going about 10 times. The washer also didn't operate, which I thought might be due to the cold, however seeing that others here have had the same problem, I am now leaning to thinking it's part of the same problem.
    Going to check things when I break for lunch in about 30 minutes. Hoping the problem has gone away, but on the other hand as long as it's covered by the warranty hoping it hasn't. Certainly I'm not up to replacing everything.
    Feb 2015
    Southampton
    Trim : Blue
    Engine : 1.9 CDTi
    Mileage : 66,500
    Well that's frustrating... I went out to the car, pressed the stick a couple of times for intermittent, and the wipers went about 1/4 of a sweep each time. Then it suddenly fixed itself.
    Now everything seems to be working perfectly, which is good, but it also means I can assume it will happen again too.
    Full Member
    Mar 2011
    n. ireland
    nothing as bad as an intermittent fault but at least you know where to come to for help
    Dec 2011
    Seaham
    Check the filter for the washer bottle, it could be blocked.
    The same pump does the front and rear washers, but runs in reverse for the rear washers. It is possible the filter on the pump is blocked.
  1. EGR valve not working properly
    By msqualo in forum Engine & Drivetrain
    Last Post: 11th June 2012, 16:56
  2. Intermediate wipers and washer jets not working
    By R2XPT in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 23:12
  3. front wipers not parking properly
    By Daywalker in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2010, 17:31
  4. Climate control not working properly
    By Aussie in forum Bodywork & Interior
    Last Post: 13th November 2007, 22:49
  5. windscreen wipers stopped working
    By dazzer t in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2007, 16:16
signum intermittent wiper not working
