Results 1 to 2 of 2
Thread: Engine Fault Codes
    Feb 2011
    Bradford
    Default Engine Fault Codes
    After many failed attempts at trying to sort out ny 2.2 dti going into limp mode i decided to get a op-com device. Worked a treat and heres what its telling me :-
    Total number of fault codes: 4
    P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    (5A) - Not present
    P0340 - Camshaft Position Sensor Circuit Range/Performance
    (FC) - Not present
    P0704 - Incorrect Clutch Switch Signal
    (0F) - Not present
    P0234 - Boost Pressure Control Circuit Positive Deviation
    (5B) - Not present
    Bearing in mind ive already cleaned my EGR and boost sensor. What do these mean...do i need a new EGR, boost sensor, canmshaft senor and clutch switch signal??? any help much appreciated thanks
    north east
    clear the codes and take the car for a drive, Im pretty sure the 2.2 doesnt have a cam sensor but its known for dti`s to chuck up a camshaft sensor when teh "Crank" shaft sensor is dying about £40.
  1. Replies: 3
    Last Post: 23rd November 2011, 15:07
  2. 2006 Signum 2.2 engine fault codes! Help please :)
    By t13con in forum Engine & Drivetrain
    Last Post: 16th January 2011, 16:39
  3. Replies: 13
    Last Post: 20th May 2010, 20:09
  4. New car fault codes and engine management
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2009, 18:47
