Thread: gear oil
    exeter
    rolleyes gear oil
    hi can anyone tell me or show a picture of where to top up and where the level nut is for my gear box . i have got a 53 vec c dti sxi .the gear box has got reverse down and back if that is any help . i got a manual but the pic is so close i can't tell where there are . i think its the f23 gear box but i could be wrong ?
    Regular Member Jezzy's Avatar
    S.E
    PM me your reg number and I "might" be able to see from ECP which box you have.
    S.E
    Reg number received via PM. There's good news and bad news. The good news is that I've been able to identify your gearbox type: it's the F23. The bad news is that EPC says your car was made in Ellesmere Port (i.e. Blighty) rather than Russelheim in Germany...lol.
    exeter
    hi jezzy .so do you have any idea where to top up and check my gear box oil?
    S.E
    According to Haynes, the level plug is on "the rear of the differential housing". It shows a flat vertical surface, with a label on it, and the plug is just above the label. Fill up until the oil reaches the bottom of the level plug hole.
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
can i fill up gearbox oil safely vauxhall signum
