Pop the bonnet and look at the bulkhead on the passenger side. You'll spot a little flap; lift it to expose the filter. There's a How2 on here.
HOW2
HOW2
i`ve done done anything with it yet its still happening im having to use my rear heater quite a bit. ive checked for leakes and its bone dry so i think i`ll give it a good clean after christmas. VX should just put little air ducts above the window!
Cheers AJA.
Thanks I'll give the filter a check but as Scott was saying. I dont think it is this as if it was wet the front screen would mist up 1st? not just the rear screen. Seems to mist up so much that there is tons of water on it!!! A little worrid that I'll have to scrape inside and out! will do the checks any how thanks again.
i dont get any water on the inside of the glass, i checked the filter today and that is fine, so i decided to clean the back window and it was filthy so im hoping this will help.
Always Had This Problem On Both My C's On Initial Start Up But Clears Very Quickly (2 Mins ) With The Rear Screen Heater On. Boot Bone Dry So I Don't Worry About It.
