Results 1 to 10 of 16
Thread: Steamy windows!
    Regular Member scott_150cdtisri's Avatar
    Jan 2006
    Crewe
    Default Steamy windows!
    hi all i have a little problem with the rear windscreen, it seems to mist up a little too easily. does this happen on all of them? when i first got the car you had to really slam the boot the shut it so i adjust the catch and this is now better. Do you think it is not closing enough now and letting moisture in? there are no wet patches in the boot.
    Cheers chaps
    The Blackburn End
    I noticed this when I first had my Signum. Since then I've cleaned, cleaned and cleaned the glass and used a good glass polish, every 2-3 weeks. Now it doesn't "mist-up" at all and stays bone dry.
    Jan 2006
    Crewe
    to be honest i didnt think water was getting in i did think that it might be there is not enough air getting back there. i shall have to try cleaning it then
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    if its just your rear window try checking under the spare wheel there might be a little water.
    if u got aircon try leaving it on
    I use my air-con all the time.... never noticed any difference in fuel economy, and it helps to keep the interior 'fog-free' all through the winter.
    Feb 2006
    Guttedsville
    check your pollen filter is dry. Change if in any doubt.
    also check it's clean!!..
    they get filthy and block the airflow..less air movement gives it chance to mist, and takes longer to clear it..
    not got a leaking bootseal have you??
    Apr 2006
    Kent
    Scott, what was the outcome. Mine is doing the same Thanks. Will try cleaning it and also the pollen filter.
    Quote Originally Posted by Andrew's SRi View Post
    This is what cured the problem with my car.
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    Whereabouts is the pollen filter in a Vec C?.
  1. steamy windows
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2012, 08:16
  2. steamy windows
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2011, 18:36
  3. Instant steamy windows
    By gsi3.2Daveyg in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2009, 14:06
  4. Steamy Windows
    By ballmonkey in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2008, 20:51
  5. Steamy windows
    By Baldy in forum Bodywork & Interior
    Last Post: 12th January 2008, 20:35
