Thread: 1.9 CDTI Turbo Problems??
    Regular Member CDTI120SXI's Avatar
    Mar 2011
    Wrexham
    Default 1.9 CDTI Turbo Problems??
    Hi, I'm looking for some help on my 05 1.9 CDTI 120.
    If i cruise a long at around 2000RPM and keep a constant speed then go to put my foot down the car will sort of jerk a bit like its loosing power and before picking up and accelerating. The best way i can describe it is the turbo cuts out and comes back in.
    Any ideas? it's driving me crazy, could it be my driving?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    In all likely hood the EGR valve is the culprit or the vacuum hoses. If these are fine or you have replaced them then I'd say the turbo vanes may be jamming, but don't go aiming for the expensive cause first, eliminate the simple and cheapest first.
    Gazza4
    Woodbridge
    2000RPM is high, turbo kicks in around 1800.
    Mar 2011
    Wrexham
    Boost pipes look ok so i guess ill replace the EGR valve.
    P.S it happens when the engine is warm.
  1. turbo problems
    By bobthebarber in forum Engine & Drivetrain
    Last Post: 22nd January 2012, 20:35
  2. Turbo problems
    By jonbav in forum Engine & Drivetrain
    Last Post: 31st March 2011, 15:44
  3. Turbo problems 2.0 Dti
    By brotherkennyh in forum Engine & Drivetrain
    Last Post: 27th August 2010, 12:19
  4. cdti 120 turbo problems (i think)
    By robhullfury in forum Engine & Drivetrain
    Last Post: 27th July 2008, 13:49
  5. Turbo problems?
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2006, 15:12
vectra c turbo problems 1.9
vectra 1.9 cdti turbo problems
vectra c 1.9 cdti turbo problems
vectra 1.9cdti turbo issues
vectra 1.9 cdti 120 turbo problems site:www.vectra-c.com
