Thread: Swirl valves
    Apr 2011
    Berkshire
    Default Swirl valves
    Can anyone tell me if the swirl valves are meant to shut when you start the car, or even shut at any point when reving it?
    Regular Member LADmachining's Avatar
    Hampshire
    The swirl valves will be closed when the engine is stopped and at low revs.
    As the engine revs increase, the flaps will move to the open position. Can't remember the exact speed at which they move, but it is around 2500-3000rpm.
    Apr 2011
    Berkshire
    mine are open at low revs and when the engine is dtopped, what can cause this?
    There is suction through the pipe but not very much
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    What is your engine as the 2.2DTI has them and they are supposedly meant to be opened when the engine is off - though not 100%.
    CDTI 150's are supposed to be closed at engine switch off. If the control rod for it is off or actuator has failed then this will cause the flaps to stay in one position.
    Gazza4
    Apr 2011
    Berkshire
    Mine is the 2.2dti, I'm currently having problems with it as in 3rd, 4th and 5th gear hit 3000rpm and goes into limp mode, i have put brand new hoses on so isn't that, i cleaned egr, and i have but new boost sensor on, I don't know what else can be, it is throwing up
    P0234-04 Boost pressure valve circuit open
    P0234-5A Boost pressure circuit negative deviation
    Sep 2010
    north east uk
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    My 2 lire DTI swirl flaps are open when engine is off, also reving the engine when stationary does not cause them to move (close).
    But i read somewhere that they only operate when the vehicle is moving & under load.
    Jul 2009
    newport
    wot on earth is a swirl valve
    Apr 2011
    Berkshire
    Quote Originally Posted by mick.n View Post
    That is good
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by MattHD View Post
    Try cleaning the boost sensor or simply try to push on the electrical connector on it
    I "cleaned" the swirl flaps on our 2.2DTI. It's fairly easy and it's called FULL THROTTLE EVERYWHERE i.e. redline revving up to 5000rpm wherever possible.
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    Quote Originally Posted by Celes View Post
    haha i like your method, and yes deffo open when the cars of,
    i your testing all your actuators, pull the vacum line of at the oposite end of the atuator, and suck the pipe, then hold your tounge over the pipe and see if it opens up again. it shouldnt.
  1. Swirl valves on an '08
    By stevoxsi in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 22:11
  2. Swirl Valves......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 5th July 2012, 19:16
  3. re swirl valves
    By steve alan in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2012, 08:52
  4. Swirl Valves
    By dhwigston in forum Engine & Drivetrain
    Last Post: 2nd March 2010, 15:13
  5. swirl valves
    By scoobyman in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2008, 21:14
