Results 1 to 10 of 11
Thread: Is changing osf drive shaft easy?
    Regular Member Craig1985's Avatar
    harwich essex
    Default Is changing osf drive shaft easy?
    As above, I'm In need of changing my driveshaft and didn't know if it's an easy thing to do? Can't find a how2 neither
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Very easy mate,
    1. Fit the space saver onto the car and let the car off the jack. Slacken off the drive shaft retaining nut
    2. Take the wheel back off and remove the track rod end from the hub carrier, remove the brake caliper and disc, then take out the bottom wishbone ball joint. This will allow the hub to move freely.
    3. Using a lever disconnect the driveshaft from the intermediate shaft, you can lever against the intermediate shaft bracket.
    4. Pull the drive shaft out of the intermediate shaft and rest it so it won't get damaged. Using a puller, pull the hub off of the drive shaft
    Oct 2007
    Shropshire
    Alternatively;
    1. Remove wheel and get someone to press the brakes whilst you slacken the drive shaft retaining nut.
    2. Remove lower arm ball joint only. Leave steering track rod and caliper and brakes in place. Steer steering to give you more room.
    3. Lever out drive shaft. A quick sharp tap with a hammer on the drive shaft will remove it without a puller. As you are replacing it there is no problem to use a hammer.
    4. Refit in reverse and tap gently back into gearbox with a mallet.
    5. Remember to refill gearbox oil which will come out when you remove it.
    harwich essex
    Thanks guys gonna give it ago
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by mucklestone View Post
    If it's the F40 gearbox then there's no way of knowing how much oil is left inside (there's no dipstick or fill-level hole), so you'll need to drain it all out and put 2.2 litres back in (about 0.2 litres will refuse to come out, so you'll end up with the required 2.4 litres).
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    No oil will come out of the gearbox as you are not removing the osf shaft from the gearbox
    Also never directly hit a drive shaft with a hammer use a block of wood. You probably will need a puller as I tried knocking it through with a block and it was stuck solid. Wouldn't want you to get it into bits and then realise you have to go and get a puller
    Oct 2007
    Shropshire
    I added the tap with hammer for good measure, mine just popped out lol.
    Oct 2007
    Shropshire
    Also you can use the metal rod method, like many garages. Before you start stick a rod down the gearbox filler hole and pull it out. You can see the level on it, mark this with paint/pen. Then when you have finished, top the box up to the same level......
    Seen this done at an actual VW dealership.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Btw Craig take John's advice as he's replaced the same part last month.
    Gazza4
    harwich essex
    Mines the osf, is it worth replacing any seals?
    It's also the 1.9cdti 150 model. So I take it that's it got the f40 box?
  1. Drive shaft
    By drummo in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2012, 13:50
  2. Drive shaft question
    By millhouse in forum Engine & Drivetrain
    Last Post: 30th May 2012, 14:43
  3. drive shaft
    By andy treg in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2011, 17:04
  4. drive shaft
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2008, 12:44
vectra c driveshaft removal
vectra drive shaft removal
vectra drive shaft
vauxhall vectra drive shaft problem
1.9 cdti drive shaft removal
osf driveshaft vectra
vectra c driveshaft
https:www.vectra-c.comforumshowthread.php135352-Is-changing-osf-drive-shaft-easy
remove vectra driveshaft
Change drive shaft Vauxhall vectrahow long to change a drive shaft vauxhall insigniahow to remove os drive shaft vectra cvectra c 1.9 cdti drive shafthow to remove drive shaft astravauxhall corsa drive shaftvauxhall vectra c drive shaft vectra c driveshaft assemblyhow muchnis a driveshaft got vauchall vectrahow to remove drive shaft vectra czafira driveshaft removalhow to replace a vectra inner drive shaft 2000corsa c driveshaft replacement costhow do you fit a drive shaft a Vauxhall sephira 2 litre dieselHow to change a driveshaft on a 2005 corsavectra b drive shaft removal
