Thread: Ecu
    Apr 2011
    wales
    confused Ecu
    I need a new ecu, chip and transponder for my vec c could I fit
    Any z22es ecu chip and transponder even if it's from a vec b or astra
    Regular Member blackveccyC's Avatar
    Dumfries
    Nope pretty sure you need vectra c mate, something to do with the cim unit isn't swappable with different makes. I'm sure someone with more knowledge will be around soon.
    Regular Member LADmachining's Avatar
    Hampshire
    You will need components from a Vectra C.
    They will also need to be divorced from the donor vehicle, otherwise you will not be able to program them into your car.
    The control units are a lot more closely linked on the newer vehicles compared to the older ones like the Vectra-B/Astra-G. Engine ECU is coded to the CIM (column module), which in turn is coded to the UEC (underhood module) REC (rear electrical module) and BCM (body control module) to name a few. All of these would need swapping from the donor car, even then it is likely the configuration of the modules would need changing to suit your vehicle.
    You would be better off getting hold of an engine ECU that has been divorced and getting that programmed into your vehicle.
    Apr 2011
    wales
    Any idea who can do ecu programing in south Wales and how much
