Thread: Temperature problems?????
    Mar 2011
    MIDDLESBROUGH
    Default Temperature problems?????
    A bit of help please. Heres the problem, when running round town the car sits at 85 degrees which i understand is normal but when doing motorway speeds the temp is around 75 sometimes a bit lower when pushing it. I have repaced the thermostat twice this year (1st one wouldnt go over 80 deg) so just wondering what it may be or is this normal???
    Going on a 800 mile road trip shortly so dont want to cause any problems is something is wrong.
    Regular Member sebadee's Avatar
    macclesfield
    Not an expert on this mate but have heard a few people talk about changing temp sender could be worth a try
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by sebadee View Post
    Apr 2011
    Toulon, France
    Quote Originally Posted by vx sri View Post
    Something is not right there, hun. Mine runs at a steady 85 degrees, no matter how I drive her.
    Takes about 3-4 miles to hit 85 from cold
    Feb 2011
    Belfast
    This happens to me also i thought this was normal.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    As tanys baby says, mine takes around 5 miles to get up to 85 degrees from cold, only time I've seen it budge from there was up a steep hill on a very hot day driving lead footed when it went, briefly, to 90 then came back down.
    Nov 2010
    East Midlands
    Trim : design
    Wouldn't worry too much - probably with the higher speeds this is cooling the engine and you have a more sensitive temp gauge that is showing this variation. I would be more worried if it was getting hotter!!
    Woodbridge
    Does it drop down from 85 when you put the heaters on full blast?
    Feb 2011
    Belfast
    In traffic it goes up to about 90 half way or slightly over.
    When i put the heater on it stays the same,it drops to about 75ish on motorway.I have just changed my thermostat i thought these temps were normal
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    Quote Originally Posted by alcutler View Post
    this is true, mines is sort of the same as yours im not worried about mine though.
  1. Temperature help!!
    By Lex82 in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2012, 15:14
  2. Temperature
    By Wolfie01 in forum Engine & Drivetrain
    Last Post: 13th February 2012, 10:34
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. 2.2 DTI Temperature problems
    By ian mc in forum Engine & Drivetrain
    Last Post: 26th January 2010, 17:29
  5. engine temperature / boost / hub problems
    By rickyroo in forum Engine & Drivetrain
    Last Post: 24th September 2007, 18:49
