Results 1 to 10 of 13
Thread: incorrect range readout from trip computer
    Oct 2010
    glasgow
    Default incorrect range readout from trip computer
    Hello guys,
    Would anyone know why my trip computer is showing that I have only zero miles of fuel till the tank is empty and its showing that the miles covered is zero also. All this and my tank is 1/4 full.
    Any help would be great thanks!
    Mo
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Is there any thing else missing, such as temperature, ignition logic or lighting control.
    Process of elimination..
    No temp read-out = faulty Low CAN wire to the BCM (Body Control Module)
    Dodgey fuel readings and possibly no Ice Crystal warning, no ignition logic, no lighting control = faulty Low CAN connection to CIM (Collumn integrated module) from the instrument cluster or BCM
    But you would get outside temperature.
    Fuel Computer only = faulty CAN connection from the UEC (Underhood electrical centre), or ABS (Anti Lock Brake System) module.
    Do the instruments register a road speed etc... - If the speedo is fine, then this rules out the ABS unit...
    I am thinking that you need a diagnostic read-out, to see which modules are not communicating.
    Finally... The display may be faulty... Problem with the internal programming. (Firmware).
    The UEC is nagging at me... if it was the CIM, then the values would come up as "F"...
    Like I said, see if anyone local to you have Tech 2, Op-Com or Vaux-Com...
    Full Member Big Sig's Avatar
    If you fill up does it change?
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I thought that at first, but for the mileage covered to be zero...
    that is a CAN fault..
    Lack of comms somewhere
    Woodbridge
    I know it will not help. But when the damn thing works, it lies anyway.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Wrong code index?
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    If the values are out by a fair margin, then I would agree with the code index issue,
    but if the Fuel Computer readings are Zero, then the Display is not getting any fuel and speed pulse information..
    Engine : 2.2 Direct
    ahhh didnt notice that bit yes could just be a broken/loose wire to the BCM..
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Aye, but which one..
    Info is normally
    ABS Module to CIM
    UEC via ECM to CIM
    CIM to Instrument Panel (pin 5)
    Instrument Panel (pin 6) to BCM (pin 41)
    BCM (Pin 40) to Display (pin 28)
    Only plausible way around this, is that the trip computer (BC) has been reset (both BC1 and BC2), and that you have put less than 10 litres of fuel in...
    Engine : 2.2 Direct
    Would actually think the problem is with the ABS module.. the plug there.. have heard about other where it helped clean out that plug..
  1. Trip computer Range accuracy
    By Casey in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2012, 18:20
  2. Help with Range feature on trip Computer
    By BRYBURN in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2009, 19:06
  3. mpg range trip computer how do you use it...
    By vec3.2 in forum Bodywork & Interior
    Last Post: 15th March 2009, 23:40
  4. Trip Computer live MPG readout.
    By pete63 in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2008, 21:36
  5. Range on Trip computer
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2007, 11:11
https:www.vectra-c.comforumshowthread.php135321-incorrect-range-readout-from-trip-computer
vectra c trip computer not correct
