Thread: Engine Diagnostic Light
    Thetford, Norfolk
    Default Engine Diagnostic Light
    Hi all
    Just a quick question is there any way of plugging in a green box without triggering the CAN-BUS in to a fault code situation as i changed my stereo on sunday which triggered a fault code and VX stung me £38 for the privilage of turning out the light even thoigh i had used a proper loom
    should also say mines a 120 sri cdti 2005
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    it shouldnt as a rule trigger any engine management lights at all UNLESS you have it set too high and it causes overfuelling to the common rail which will then lodge a complaint. Assuming the 'green box' your talking bout is a tuning box.
    Thetford, Norfolk
    yes its a powerklip box was just wondering if there was any special treatment you needed to give it like disconnecting the battery that was all
    Quote Originally Posted by plasma
    no, no special treatment.. just make sure the key isn't in the ignition when you break into the common rail multiplug with the bridgeing loom of the box..
    unless it's too high as plamsa said, it should be straightforward
    Regular Member ion's Avatar
    walsall
    Is it possible to connect the green box backwards like the CR1?
    When you turn the key this will trigger the fault light & will do so every time you turn the key then for a while, even when you correct it I think?
    I connected my CR1 backwards once.
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    To clear the code you can disconnectt your battery for half hour, you'll have to re-enter your radio code and that but its a proven way to clear the light. It worked on mine fine.
    Thetford, Norfolk
    Cheers for the info guys. Not worried about the radio code as mine has been changed so only have to worry about reprogramming radio stations cheers for the tip plasma its cheaper than having to pay vx £38 to reset the EML
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  4. U480 diagnostic Scanner, can engine be running when reading codes
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2010, 11:58
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
