Thread: Random Power Steering Failure
    Lincs
    Default Random Power Steering Failure
    Hi all.
    Filled up with fuel, started car, drove off and, have i 2 flat tyres? Power steering lamp on on dash. Pulled in and turned engine off. Restarted and fault cleared, been ok for 300-400 miles.
    Is this just a totally random fault or is there something i need to be checking out please?
    Thank you.
    Paul.
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Check the power steering fluid level and the voltage across the battery with the engine running, should be 13.5-14.4v, is where i would start.
    kilmarnock
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Agree with this I had similar with my 1.9 cdti (120) estate just returning home from a 100 mile no problem journey - stopped at a junction and warning light came on dash and lost power steering for a few seconds. Tried power steering fluid and connections to power steering pump as previously suggested - but in the end replaced the alternator and battery and never had problem since.
    I changed the alternator first, ran a diagnostic check and found it was showing a fault on the charging system. Eventually replaced the battery and been fine since. Oddly enough the old battery was a Bosch 90 amp hour one - I replaced it with a genuine GM one for my vehicle and this is only rated at about 70 amp hour, so I assume there was a mismatch between the alternator and the battery that threw up that fault. The Bosch battery was put on another car I have and went through the last extreme winter without a problem.
    Seems that the alternator / battery setup is quite sensitive on the Vectra and this can affect the power steering in the way you describe.
    Good luck with it!
    Lincs
    Thanks chaps, i did check the level at the time and it was fine. I'll check the battery next.
    Thank you.
  1. Power Steering Failure
    By MadOnVaux! in forum Suspension, Wheels & Brakes
    Last Post: 17th December 2011, 23:40
  2. Power Steering Failure
    By derrybulmers in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 20:10
  3. Power steering failure
    By Chris06v6 in forum Engine & Drivetrain
    Last Post: 28th July 2011, 06:22
  4. Power Steering Failure
    By Medc in forum Suspension, Wheels & Brakes
    Last Post: 16th November 2010, 12:19
  5. Power Steering Failure
    By gsi.vxr in forum Engine & Drivetrain
    Last Post: 26th October 2010, 15:01
