Results 1 to 10 of 19
Thread: were to put gear oil
    sheffield
    Default gear oil
    were do you put gear oil on a vectra c sri please help
    sheffield
    Default were to put gear oil
    were to put gear oil in a vectra c sri help please
    Mileage : 000
    If you mean in the gear box. I put it in through the reversing light switch. But there should be a filler level plug on the side of the gear box.
    sheffield
    were that mate
    Regular Member Jezzy's Avatar
    S.E
    Depends on which engine/gearbox you have.
    S.E
    Quote Originally Posted by ed taylor View Post
    No, it depends on which engine and gearbox he has, and at the moment there's nothing in his profile to give us a clue about that.
    sheffield
    its a 1.8 sri mate
    S.E
    Then you've got an F17 gearbox. Remove the oil level plug, which is behind the driveshaft inner joint on the passenger side of the gearbox. Then pour in the new oil through the reversing light switch until it reaches the bottom of the level plug hole.
    Mileage : 000
    Sounds much like my discription, only I did at the time not know the type of gearbox, so could not say where the llevel plug is.
    sheffield
    thankyou mate for your help
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
