Thread: Symptoms of a Broken Spring
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Symptoms of a Broken Spring
    Heard a loud bang as I got in the car this morning.
    If it was a spring snapping what are the symptoms and what is the driveability of the car like?
    Thanks.
    Regular Member Mopar Man's Avatar
    herts
    You need to have a look under the front wheel arches and see if the spring is broken first. Can be Dangerous, if the broken spring goes through the tyre.
    Regular Member Exclusive BV's Avatar
    West Midlands
    Could have just been the hand brake. Sometimes they make this type of noise when they are not applied tight enough.
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    UPDATE:
    Front passenger spring was snapped, had the front two replaced for £170.10 including tracking at Kwik Fit.
    Whats peoples opinion on the price I paid, I thought it was reasonable (ish)?
    Vauxhall quoted me £360.00
    Regular Member *enery*'s Avatar
    Mar 2007
    glasgow
    ye that sounds a fair price bud
    Regular Member mann3210's Avatar
    scotland, perth
    could of got lowering springs for that!
    Feb 2011
    barnsley
    Quote Originally Posted by mann3210 View Post
    then he would've had to pay for 4 springs fitting instead of 2!! also he may not want it lowering!!
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by actionman View Post
    Quite right, I thought that post was meaningless, ALL I wanted to know was peoples opinions/views on the prce I paid.
    Regular Member Jezzy's Avatar
    S.E
    You can't directly compare the Kwik Fit price with the Vauxhall dealer's as they don't use the same quality of spring. The Kwik Fit price should be compared with ATS or other high street chains.
    Jun 2006
    Near Edinburgh
    What he said. Kwik Fit will have used pattern parts from a local motor factor etc. which are a lot cheaper thant he GM springs. The £360 you were quoted from the dealer though is a reasonable price when using GM components as the spring costs are mega.
  1. How would i know if ive got a broken spring ???
    By wardy23 in forum Suspension, Wheels & Brakes
    Last Post: 6th October 2012, 10:28
  2. broken spring
    By niicckk in forum Suspension, Wheels & Brakes
    Last Post: 2nd October 2012, 19:51
  3. broken spring
    By b1lly in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2012, 16:54
  4. Broken spring
    By grumpano in forum Handling & Braking
    Last Post: 28th February 2008, 21:34
  5. symptoms of half broken suspension springs
    By ozzye in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2007, 22:59
