Results 1 to 10 of 16
Thread: Air con compressor problems
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Air con compressor problems
    Not the usual air con problem so please read on.
    Obviously with the better weather coming in i've been using the air con more often and it's been brilliant until today.
    I was heading into to Dundee and got stuck in some traffic and smelled an electrical/burning brakes sort of smell. At first I thought it was the clutch as I was on a rather steep hill but for a while after I could still smell it.I also noticed that the air con wasn't very cold.
    When I parked up I lifted the bonnet and at the aux belt side of the car I could smell the same smell which kinda rules out clutch/brake problems.
    Anyone had a similar problem, has the ac clutch maybe failed?
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    get someone to turn the air con on while you look at the commpressor you can normaly see the clutch turn on it does sound like the clutch has given up
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Cheers for the input mate, any idea if the clutch can be changed on it's own
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Me Is Watching As Got Same Problem
    Can Smell It A Wee Bit Inside..Get Out Drivers Door And The Guff Hits You In The Face
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Bump
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Right, it is definatly an air con problem. I have had a look at the compressor and the centre turns easily by hand so it's not seized. Switching the a/c switch on/off does absolutly nothing and the centre of the compressor does not start turning.
    The electrical smell seems to be gone too sooo.... my guess is it either needs regassing and that it just ran out of gas yesterday, a fuse has popped somewhere in the system (it's not the 10a one under the bonnet as i've looked at that one) or there is some thing more serious wrong with it
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Relay for the clutch? Maybe that was the burning smell.
    Gazza4
    Wales
    If you can (could) smell burning, there is no reason to assume it has no gas; sounds like something electrical has burned out; relay or A/C pump motor
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Maybe, but where is it
    Quote Originally Posted by snapsnap View Post
    Reason I think the gas may be out is that the compressor won't kick in and there isn't even any waver in the revs of the car when the button is pressed. I thought that the gas had maybe just run out at that moment causing the clutch to partially disengage and cause the burning smell
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    According to the link below suspect fuses/relays could be:
    https://www.vauxhallproductforum.co....icles/2217.pdf
    Passenger side fuse panel: Fuse 2, 23, 25
    Then I couldn't tell you what the relays are in the engine fuse box.
    Gazza4
  1. Air Con Compressor
    By Siggy08 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2012, 15:52
  2. air compressor
    By 06sri in forum General Chat
    Last Post: 15th September 2012, 16:22
  3. Air Con Compressor
    By Bigwelshfella in forum Engine & Drivetrain
    Last Post: 2nd May 2011, 13:33
2011 insignia air con relay
