Thread: House Door Locks
    Regular Member vectraboyy's Avatar
    Default House Door Locks
    Hello wise people!
    I need to change the locks on my house buti was wondering if there was anyw ay to know exactly what you needed without taking out the locks?
    I have three to replace, two from plastic doors and one wood door. But not sure on how you know which one to get...
    Any help greatly appreciated.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    If the "plastic doors" are UPVC, I'd get a locksmith in, they have locking bolts and everything has to be right and line up. I wouldn't mess with one.
    Wooden, for a yale type you need to know if it's narrow or wide fitting, most mortice locks are similar fitting, just some more secure than others.
    [Ex]Admin Duncan's Avatar
    If the ones on the uPVC doors are euro cylinders then they're a doddle to replace (just done mine recently for a master keyed Mul-T-Lok system) and won't affect any locking bolts etc. You just need to make sure you get the right length (offset) of cylinder which you can measure once it's out. Couple of pics of the locks would help advise.
    Chelmsford
    I agree with Duncan. the cylinders themselves are very very easy to replace. Just a case of take out a screw, slot out the cylinder, slot in the new one.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    easy peazie so simple there a joke. PVC Doors, open the door and look at the face plate that the lock comes through, remove the small screws top and bottom on the plate and remove the plate. With the plate removed look at the rectangular locking bolt and underneath it is a small flat head screw, start unscrewing it, this is the what holds the euro lock in place. Once you've removed this screw put the key in the lock and rotate the key slightly either left or right and the lock will just pull out. As duncan says youll need to remove the euro locks and measure them as they are all different lengths. Check Screwfix for replacements as they are an awful lot cheaper than B&Q or a locksmith. Screwfix even sell pairs that only require one key for both doors.
    Wooden doors should just be a 5 or 7 lever lock and are even easier to remove. 2 screws hold the plate on, remove them and 2 screws securing it to the door. May even just be 2 screws in total.
    Ah cool.
    There the UPVc ones which just need the cylinder. Good that it seems easy peasy though, will try and get some pics up.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    I was going to expand on that (the measuring bit) but came across this article which covers it exactly. So the cylinder in that article would be referred to as a 25/35, or 70 25/35 if you wanted to be absolutely correct!
    The bit about it not sticking out too far on the outside is important. If it's too much then toerags who have got hold of a certain locksmiths tool can basically get purchase on the profile and snap the cylinder, thus releasing the lock!
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Ok, I was going on the council oohing, arrhing, and the long list of problems they reckoned to have to overcome, never had to do UPVC myself, wood doors are easy.
  1. Auto Door Locks.
    By Hynzy in forum Insignia car chat
    Last Post: 29th November 2009, 17:52
  2. programming the door locks
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2008, 16:34
  3. Door Locks
    By cant stand honda's in forum Electrical & ICE (including SatNav)
    Last Post: 1st September 2008, 18:41
