Thread: How many amps......
    Essex
    Default How many amps......
    I dont know if this is the right section to post this question in but here it is anyway:
    How many amps can the wiring to the headlights in the vectra C take?
    Thank you
    Regular Member stickshift's Avatar
    North London
    Hi bigdan
    Don't Know what max limit is but with the standard bulbs - 55w the wiring is taking 4.58 amps.
    Divide the watts by volts and it gives you your amps.
    Essex
    Basically what I would like to know is can I run 100w bulbs on the standard wiring? I work this out to be about 8.4 amps. I REALLY don't want to start messing with relays and extra wires so if I can get away with it then I will be very happy.
    North London
    I think e.u. law says 55w is as high as you can go without your bulbs being to bright for on coming traffic. So come MOT time it might fail! Plus it might damage you lenses.
    Essex
    Obviously if I had any problems with the brightness for oncoming vehicles I would adjust them down or if neccessary replace the original bulbs. I am fairly sure the lenses will be able to cope.
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    Exclamation
    Wiring is usaully ok with 100w bulbs but tis the Switch that may give up after a while
    Essex
    Are they not on a relay?
    Hertfordshire
    Quote Originally Posted by Maddog1974
    Except due to the canbus wiring, the headlights aren't directly connected to the switch, they are turned on by a module, and that's what you are most likely to fry if you overload it !!!
    Quote Originally Posted by bigdan
    It's hard to say now a days, but not necessarily.
    Just be carefull guys.
  1. How many amps should it be?
    By rickisgrate in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2013, 08:08
  2. Amps to the Std Radio ?
    By andymagee1982 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2009, 14:43
  3. 2 x directed amps
    By Mac in forum General items for sale
    Last Post: 22nd April 2008, 18:41
  4. Amps
    By PeteRs in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2008, 16:00
  5. amps for sale
    By chrisgettings in forum General items for sale
    Last Post: 26th August 2007, 10:17
