Thread: The new brakes, 400 miles later
    Leicester
    Default The new brakes, 400 miles later
    After doing 400 miles on the new brakes, I haveto say what an improvement, much less force require on the pedal than befre to get equal stopping power, but when you hit them hard you really notice how efficient they are.
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    You should have gotten those VXR brakes....I regularly have to peel the wife off the inside of the windscreen ;>
    spoons
    Guest
    Sounds good Matt.... Just waiting now to get all my costs together....
    I feel another imminent purchase coming along
    spoons
    Guest
    Quote Originally Posted by In a states
    VXR Brakes are in a different price bracket all together...
    approx £750 for fronts and £450 for rears.....
    Whereas Matt's set would cost around £300-350 normally (Without favours or special deals)
    Now in Girvan Scotland
    Just Replaced The Fronts With Vx Originals, What A Load Of ...p, Screech Like Mad At All Speeds And Will Be Going Back Next Week When I Am Off Work, I Am Not Accepting This As They Are Turning Heads For The Wrong Reason !
    Leicester
    It is a big job to fit VXR brakes to lesser models.
    The disc dust sheild will only accomodate upto the 314mm disc, so unless you want to hack it off in a bodge job way, the hub will have to be removed from the driveshaft to either fit VXR sized dust sheilds or to remove the smaller sheilds all together.
    And as Steve has said, the VXR kit is a big jump price wise, if you take into account the weight saving of the 1.9 over the VXR, the 314mm brakes should not be that far off the actual braking performance of the VXR itself.
    Yes fitting the VXR set up would be a bigger jump performance wise, I am more than happy with these, LMF does the trick again!!!!
    Jan 2006
    Hornchurch
    the V6 set up is a 30 min job to fit to 4 pot cars an works very well for the money
    say you could go for 4 or 6 pots but your looking at over £1000 vs £300
    Regular Member Vectra.c's Avatar
    Feb 2014
    pembrokeshire
    Vehicle : vectra
    Trim : elite estate
    Engine : 150bhp cdti
    Mileage : 212,000
    I'll be doing my brake upgrade soon!
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Ok, just how many miles has my car done?
    By cont1204 in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2011, 20:59
  3. Fed up 2nd DMF in 12,000 miles
    By monty2000 in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2010, 14:05
  4. Replies: 28
    Last Post: 9th May 2009, 20:26
  5. How Many Miles !!!
    By Damian in forum General Chat
    Last Post: 10th August 2006, 22:29
