Results 1 to 10 of 18
Thread: the "10k boost"
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default the "10k boost"
    from what i can gather, you take this stuff and introduce it into the intake and its supposed to "clean" the intake system of carbon and deposits?.... is this right and how affective is it.
    al.
    Regular Member ScottyV6's Avatar
    Feb 2011
    Worcester
    you will get mixed reviews about this but I used it on my old Nissan Primera and my wife's old KA and noticed an immediate improvement. annoys the neighbours when your revving it through though! however I've been doing some research into spray through cleaners recently and I'm bending towards either BG44K or Comma d-tox. BG44K has great reviews across the pond and used by big name German garages as part of service now but pricey stocked by kwiksh*t. and the Comma has the same active ingredients but less than half the price.
    I like the claims that they don't increase bhp but help to restore it!
    Sep 2010
    rotherham
    Vehicle : 1.9cdti,sri
    Trim : duel exhausts
    Year : 55
    Mileage : 117,000
    rolleyes daz i had to
    mate i to had replace the egr valve on my 120 cdti but it still didnt feel right so i tried the 10k boost which is easy to do but is a 2 man job and its made such a difference its a lot smoother more responsive and better mpg its 20 quid but well worth it daz
    Regular Member farley2708's Avatar
    antrim n.ireland
    have to agree with above,done mine about 3 months ago,cleaned boost sensor,noticed a big difference in smoother accleration up through the gears,2 man job,1 spraying & 1 on the throttle,a lot of nice whiteish grey then black smoke...........................all the s*** inside comming out
    north east
    wynns egr cleaner is cheaper , carb cleaner is even cheaper.
    out of interest why cant it be sprayed down the oil breather connetion on the throttle body / egr ? or has no one done that ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by roswell View Post
    There is no oil breather connection on the throttle body.
    I ain't a fan of this as by accounts it sounds like the engine doesn't like it - when you hear of the smoke that it pours out.
    Gazza4
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    so its supposed to get rid of the carbon deposits in the intake?.. well from what iv seen, thats quite a mighty task and specially on the diesels that mix hot gas with oily intake air as it gums the intake up bad and i for one cant see a bottle of quick fix getting rid of the build up.
    only thing i can see it doing, is dissolving the area it "touches" and maybe cleaning the valve seats?... and as gazza said, i dont like the idea of the cleaner plus the rubbish it takes with it getting burnt in the cylinders as id say that would lead to varnishing of the bores or even taking the much needed gum off the piston rings that aids compression in older cars.
    iv asked cos my 2.2 dti's intake is pretty gummed up and i recon it needs taking off and giving a damn good clean but it looks a pretty involved job and wondered about this 10k stuff but i dont think il bother.
    al.
    May 2006
    scotland
    I have used carb cleaner twice a year for the last 6 years on my 1.9CDTI. I just disconnect the inlet pipe to the turbo then slowly spray as it idles. I press the throttle every now and then to blast it round the system. When I put everything back, I have to clear the spanner light with my code reader as the MAF sensor is effectively disconnected during the process.
    Works great for me, no problems yet and a smooth runner always.
    Sep 2010
    rotherham
    Year : 55
    Mileage : 117,000
    Default daz
    if its bad for or going to do any damage to the engine then there would be a write up some where but i havent found one i did some research before i bought it and found only good reveiws about it if you dont want to use 10k halfords sell wynns fuel addative for about £15.00 which is supposed to be as good but for best results you are better going for a long run hope this helps
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  3. "Goodbye" blue sky "Hello" grey !
    By FIL 4822 in forum General Chat
    Last Post: 8th November 2008, 15:43
  4. "Goodbye" grey sky, "hello" blue !
    Last Post: 24th October 2008, 12:34
  5. end of year bash 2008 "" will there be one ""
    By chrisgettings in forum General Chat
    Last Post: 3rd September 2008, 10:26
